ارتباط با ماژول شبکه w5100 از طریق پروتوکل TCP/IP
برای ارتباط با آردوینو از طریق پروتوکل محبوب TCP/IP میتونید از کد زیر استفاده کنید
این کد اطلاعات دریافتی از طریق شبکه رو به پورت سریال انتقال میده
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address, IP address and Portnumber for your Server below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress serverIP(192,168,195,214);
int serverPort=8888;
// Initialize the Ethernet server library
// with the IP address and port you want to use
EthernetServer server(serverPort);
// start the serial for debugging
// start the Ethernet connection and the server:
Ethernet.begin(mac, serverIP);
server.begin();
Serial.println("Server started");//log
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
String clientMsg ="";
while (client.connected()) {
if (client.available()) {
char c = client.read();
//Serial.print(c);
clientMsg+=c;//store the recieved chracters in a string
//if the character is an "end of line" the whole message is recieved
if (c == '\n') {
Serial.println("Message from Client:"+clientMsg);//print it to the serial
client.println("You said:"+clientMsg);//modify the string and send it back
clientMsg="";
// give the Client time to receive the data
delay(1);
// close the connection:
client.stop();
