نمایش نتایج: از 1 به 5 از 5
Like Tree4 لایک
  • 2 Post By magmagmary
  • 1 Post By magmagmary
  • 1 Post By dogdoor313
موضوع: ماژول صفحه نمایش ماتریسی 16 * 16 تک رنگ
نام: 00100-071.jpg
مشاهده: 254
حجم: 47.1 کیلو بایت
    نمونه کد :
      * Show messages on an 8x8 led matrix,
      * scrolling from right to left.
      * Uses FrequencyTimer2 library to
      * constantly run an interrupt routine
      * at a specified frequency. This
      * refreshes the display without the
      * main loop having to do anything.
    #include <FrequencyTimer2.h>
    #define SPACE { \
         {0, 0, 0, 0, 0, 0, 0, 0},  \
         {0, 0, 0, 0, 0, 0, 0, 0} \
    #define H { \
         {0, 1, 0, 0, 0, 0, 1, 0}, \
         {0, 1, 1, 1, 1, 1, 1, 0}, \
         {0, 1, 0, 0, 0, 0, 1, 0}  \
    #define E  { \
         {0, 1, 0, 0, 0, 0, 0, 0}, \
         {0, 1, 1, 1, 1, 1, 1, 0}  \
    #define L { \
    #define O { \
         {0, 0, 0, 1, 1, 0, 0, 0}, \
         {0, 0, 1, 0, 0, 1, 0, 0}, \
         {0, 0, 0, 1, 1, 0, 0, 0}  \
    byte col = 0;
    byte leds[8][8];
    // pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
    int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
    // col[xx] of leds = pin yy on led matrix
    int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
    // row[xx] of leds = pin yy on led matrix
    int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
    const int numPatterns = 6;
    byte patterns[numPatterns][8][8] = {
       H,E,L,L,O,SPACE
    int pattern = 0;
       // sets the pins as output
       for (int i = 1; i <= 16; i++) {
         pinMode(pins[i], OUTPUT);
      // set up cols and rows
       for (int i = 1; i <= 8; i++) {
         digitalWrite(cols[i - 1], LOW);
         digitalWrite(rows[i - 1], LOW);
      clearLeds();
      // Turn off toggling of pin 11
       FrequencyTimer2::disable();
       // Set refresh rate (interrupt timeout period)
       FrequencyTimer2::setPeriod(2000);
       // Set interrupt routine to be called
       FrequencyTimer2::setOnOverflow(display);
      setPattern(pattern);
         pattern = ++pattern % numPatterns;
         slidePattern(pattern, 60);
    void clearLeds() {
       // Clear display array
       for (int i = 0; i < 8; i++) {
         for (int j = 0; j < 8; j++) {
           leds[i][j] = 0;
    void setPattern(int pattern) {
           leds[i][j] = patterns[pattern][i][j];
    void slidePattern(int pattern, int del) {
       for (int l = 0; l < 8; l++) {
         for (int i = 0; i < 7; i++) {
             leds[j][i] = leds[j][i+1];
           leds[j][7] = patterns[pattern][j][0 + l];
         delay(del);
    // Interrupt routine
    void display() {
       digitalWrite(cols[col], LOW);  // Turn whole previous column off
       col++;
       if (col == 8) {
         col = 0;
       for (int row = 0; row < 8; row++) {
         if (leds[col][7 - row] == 1) {
           digitalWrite(rows[row], LOW);  // Turn on this led
         else {
           digitalWrite(rows[row], HIGH); // Turn off this led
       digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
    کتابخانه در فایل ضمیمه
    Jul 2016
    سلام میشه یه راهنمایی بهتر بکنید مخصوصا قسمت بستن مدار رو نمیدونم چیکار کنم .عکس اصلا مربوط به این نیست کد هم مربوط به 8x8 است نه این لطفا کمک کنید
    این برای مدل 8*8* هست که اگه بخواید برای 16*16 استفاده کنید باید کد رو تعمیم بدید
    میتونید از این لینک برای 16*16 استفاده کنید:
    [Tutorial] How to use Dot LED Matrix Display with Arduino – Rhesoft
    Jul 2016
    A ->5
    B->4
    C->3
    D->2
    EN/OE->6
    R1->7
    SCK->8
    LAT->9
    #include "LedMatrixObject.h"
    LedMatrixObject *a = new LedMatrixObject(2, 3, 4, 5, 6, 7, 8, 9);
    unsigned char s[16][16] = {
    {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1},
    {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1},
    {1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 1, 1, 1, 1, 1, 0, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 1, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 1, 1, 0, 0, 1, 0, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 1, 0, 1, 0, 1, 0, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 0, 1, 1, 0, 1, 0, 1, 1, 0, 1, 1, 0, 1, 0, 1},
    {1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1},
    void setup(){
    void loop(){
    a->setScene(s);
    a->draw();
    تصاویر کوچک شده (Thumbnails) پیوست شده تصاویر کوچک شده (Thumbnails) پیوست شده img_20160716_102637-1-.jpg   img_20160716_102648-1-.jpg
    ویرایش توسط dogdoor313 : 07-19-2016 در ساعت 11:03 AM
    سلام.
    هر چه سرچ کردم چیزی که دقیقا پین ها و بوردش مثل این (محصول موجود در سایت آفتاب) باشه ندیدم!
