4 فایل پیوست
ماژول بلوتوث ورژن 4 NRF51822 Beacon دارای قابلیت ارتباط با اندروید / IOS
پیرو اینکه دیتا بیشتری به این کالا اضاف کنم مشتاق بودم توضیحات زیر با دوستان به اشتراک بذارم
فایل پیوست 2904
Introduction
Overview
The NRF51822 beacon module is a portable iBeacon tag with ultra low power chipset NRF51822 and leverage BLE 4.0 technology.It has a portable case size, accurate hardware and robust firmware. It is designed for the commercial advertising and in-door location-based service.
NRF51822 beacon broadcast 2.4GHz radio signals at regular and adjustable intervals when it is power on. It can be heard and interpreted by iOS and Android BLE devices that are equipped with many mobile apps.
Description and Characteristics:
فایل پیوست 2905
1. Easy and rapidly to customize a casing in very low cost;
2. UUID, Major, Minor and other parameters can be changed by customer;
3. iBeacon with battery holder,easy test and use.
4. Based on Nordic NRF51822 & CR2032 ,bluetooth low energy module;
5. Support for IOS7.0 / Android 4.3 / or above;
6. Effected range: 60M;
7. Low energy module for battery life one years;
فایل پیوست 2906
Feature
Built-in iBeacon firmware
Built-in a coin battery holder
Bluetooth low energy technology compatible
Accurate digital RSSI
High performance and ARM CortexTM-M0 32 bit processor 128 bit AES HW encryption
Tested with iOS 7.0
Applications
Indoor navigation
mobile payment
in-store promotions specialist flow analysis
iBeacon Descriptions
Run standalone as iBeacon, External host is not required.
Application for advertisement and location.
Support customize your own iBeacon configuration including UUID etc.
Built in JTAG port for customized other application firmware as a standalone system.
Electrical Characteristics
فایل پیوست 2907
مرجع
Be Good:rolleyes:
