لطفا نحوه کار با ماژول سنسور تشخیص آتش و شعله - سنسور مادون قرمز را همراه با یک کد نمونه قرار دهید. در اینترنت چیزی براش پیدا نکردم.
کد://You may copy, alter and reuse this code in any way you like but please leave reference to HobbyComponents.com in your comments if you redistribute this code.
//This code is modified by Ahlskog Niki & Borgström Anders
//SENSOR PINOUT:
PIN 1: Analogue out
PIN 2: Ground
PIN 3: +5V
PIN 4: Digital out
#define FLAME_DETECT_ANA A0 // Select the input pin for the flame detectors analogue output.
#define FLAME_DETC_DIO 2 // Select the input pin for the flame detectors digital output.
int led = 8; // Select the input pin for the led
void setup() // Initialize serial and DIO
Serial.begin(9600); // Setup the serial port for displaying the status of the sensor
pinMode(led, OUTPUT);
pinMode(FLAME_DETC_DIO, INPUT); // Configure the DIO pin the sensors digital output will be connected to
void loop() // Main program loop
Serial.print("Sensor Value: "); // Read the sensors analogue output and send it to the serial port
Serial.print(analogRead(FLAME_DETECT_ANA));
if (digitalRead(FLAME_DETC_DIO)) // Read the status of the sensors digital output and if it is high then send an alert to the UART and the led is lighten
Serial.println(" FLAME DETECTED!");
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
}else // Otherwise the there is no alert and the led is shut down
Serial.println();
من کد رو به صورت زیر عوض میکنم
دلیلش اینه ماژول سایت فقط D0 داره و این کد برای A0 D0 نوع دیگری 4 پایه ماژول هست نه 3 پایهکد:
//SENSOR PINOUT:
if (!digitalRead(FLAME_DETC_DIO)) // Read the status of the sensors digital output and if it is high then send an alert to the UART and the led is lighten
Serial.println();
در نتیجه همیشه flame detected میده
که من یه delay اضافه کردم و قسمت digitalRead(FLAME_DETC_DIO) رو not کردم
توضیحات تکمیلی
.کد:
How it works:
The flame sensor is very sensitive to IR wavelength at 760 nm ~ 1100 nm light.
Analog output (A0): Real-time output voltage signal on the thermal resistance.
Digital output (D0): When the temperature reaches a certain threshold, the output high and low signal threshold adjustable via potentiometer
سلام من میخواستم سنسور تشخیص شعله و سنسور تشخیص گاز کربن مونواکسیدmq-7رو ترکیب کنم که با هم کار کنن ولی کداشو نتونستم با هم اجرا کنم اگه میشه کدشو برام بفرستین یا در سایت قرار بدین
اینو تست بگیرید
کد:int flame = A0 , gas = 3;
pinMode(gas, INPUT);
Serial.println(gasData());
Serial.println(flameData());
int gasData() {
int data = analogRead(gas);
return data;
int flameData() {
int data = digitalRead(flame);
return data;
