شیلد جوی استیک آردوینو (دو محوره)
after opening the serial monitor, you should see different values printed on a line and refreshed very quickly. these are the state of the various buttons present on the joystick shield, as well as the
.current position (x and y value) of the joystick
// Store the Arduino pin associated with each input
// Select button is triggered when joystick is pressed
const byte PIN_BUTTON_SELECT = 8;
const byte PIN_BUTTON_F = 7;
const byte PIN_BUTTON_E = 6;
const byte PIN_BUTTON_RIGHT = 3;
const byte PIN_BUTTON_UP = 2;
const byte PIN_BUTTON_DOWN = 4;
const byte PIN_BUTTON_LEFT = 5;
const byte PIN_ANALOG_X = 0;
const byte PIN_ANALOG_Y = 1;
pinMode(PIN_BUTTON_RIGHT, INPUT);
digitalWrite(PIN_BUTTON_RIGHT, HIGH);
pinMode(PIN_BUTTON_LEFT, INPUT);
digitalWrite(PIN_BUTTON_LEFT, HIGH);
pinMode(PIN_BUTTON_UP, INPUT);
digitalWrite(PIN_BUTTON_UP, HIGH);
pinMode(PIN_BUTTON_DOWN, INPUT);
digitalWrite(PIN_BUTTON_DOWN, HIGH);
pinMode(PIN_BUTTON_SELECT, INPUT);
digitalWrite(PIN_BUTTON_SELECT, HIGH);
pinMode(PIN_BUTTON_E, INPUT);
digitalWrite(PIN_BUTTON_E, HIGH);
pinMode(PIN_BUTTON_F, INPUT);
digitalWrite(PIN_BUTTON_F, HIGH);
Serial.print("U:");
Serial.print(digitalRead(PIN_BUTTON_UP));
Serial.print(" ");
Serial.print("R:");
Serial.print(digitalRead(PIN_BUTTON_RIGHT));
Serial.print(" ");
Serial.print("D:");
Serial.print(digitalRead(PIN_BUTTON_DOWN));
Serial.print(" ");
Serial.print("L:");
Serial.print(digitalRead(PIN_BUTTON_LEFT));
Serial.print(" ");
Serial.print("x:");
Serial.print(analogRead(PIN_ANALOG_X));
Serial.print(" ");
Serial.print("y:");
Serial.print(analogRead(PIN_ANALOG_Y));
Serial.print(" ");
Serial.print("S:");
Serial.print(digitalRead(PIN_BUTTON_SELECT));
Serial.print(" ");
Serial.print("F:");
Serial.print(digitalRead(PIN_BUTTON_F));
Serial.print(" ");
Serial.print("E:");
Serial.print(digitalRead(PIN_BUTTON_E));
Serial.print(" ");
Serial.println();
