مشکل با اپلود برنامه به صورت وای فای روی برد Wemos D1
من وقع اپلود برنامه ها به این ارور بر میخورم python هم نصب کردم
Arduino: 1.8.0 (Windows 10), Board: "WeMos D1(Retired), 80 MHz, 115200, 4M (3M SPIFFS)"
Sketch uses 222209 bytes (21%) of program storage space. Maximum is 1044464 bytes.
Global variables use 31576 bytes (38%) of dynamic memory, leaving 50344 bytes for local variables. Maximum is 81920 bytes.
java.io.IOException: Cannot run program "python.exe": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.GenericNetworkUploader.uploadUsingPreferences(GenericNetworkUploader.java:99)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:709)
at processing.app.SketchController.exportApplet(SketchController.java:682)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2190)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 8 more
An error occurred while uploading the sketch
