نمایش نتایج: از 1 به 9 از 9
موضوع: نیاز به کمک در راه اندازی tft با کتابخانه utft
    Feb 2016
    هنگام استفاده از کد مثال کتابخانه با پیام خطای زیر مواجه میشم و کامپایل نمیشه.
    C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:21:14: error: variable 'SmallFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
    fontdatatype SmallFont[1144] PROGMEM={
    C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:125:14 : error: variable 'BigFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
    fontdatatype BigFont[3044] PROGMEM={
    C:\Program Files (x86)\Arduino\libraries\UTFT\DefaultFonts.c:234:14 : error: variable 'SevenSegNumFont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
    fontdatatype SevenSegNumFont[2004] PROGMEM={
    Feb 2016
    با نصب دوباره کتابخانه مشکل حل شد ولی صفحه سفیده این هم کد:
    UTFT myGLCD(SSD1289,38,39,40,41);
    randomSeed(analogRead(0));
    // Setup the LCD
    myGLCD.InitLCD();
    myGLCD.setFont(SmallFont);
    int buf[318];
    int x, x2;
    int y, y2;
    int r;
    // Clear the screen and draw the frame
    myGLCD.clrScr();
    myGLCD.setColor(255, 0, 0);
    myGLCD.fillRect(0, 0, 319, 13);
    myGLCD.setColor(64, 64, 64);
    myGLCD.fillRect(0, 226, 319, 239);
    myGLCD.setColor(255, 255, 255);
    myGLCD.setBackColor(255, 0, 0);
    myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
    myGLCD.setBackColor(64, 64, 64);
    myGLCD.setColor(255,255,0);
    myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 227);
    myGLCD.setColor(0, 0, 255);
    myGLCD.drawRect(0, 14, 319, 225);
    // Draw crosshairs
    myGLCD.setBackColor(0, 0, 0);
    myGLCD.drawLine(159, 15, 159, 224);
    myGLCD.drawLine(1, 119, 318, 119);
    for (int i=9; i<310; i+=10)
    myGLCD.drawLine(i, 117, i, 121);
    for (int i=19; i<220; i+=10)
    myGLCD.drawLine(157, i, 161, i);
    // Draw sin-, cos- and tan-lines
    myGLCD.setColor(0,255,255);
    myGLCD.print("Sin", 5, 15);
    for (int i=1; i<318; i++)
    myGLCD.drawPixel(i,119+(sin(((i*1.13)*3.14)/180)*95));
    myGLCD.setColor(255,0,0);
    myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,119+(cos(((i*1.13)*3.14)/180)*95));
    myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,119+(tan(((i*1.13)*3.14)/180)));
    delay(2000);
    myGLCD.setColor(0,0,0);
    myGLCD.fillRect(1,15,318,224);
    // Draw a moving sinewave
    x=1;
    for (int i=1; i<(318*20); i++)
    x++;
    if (x==319)
    x=1;
    if (i>319)
    if ((x==159)||(buf[x-1]==119))
    myGLCD.setColor(0,0,255);
    myGLCD.drawPixel(x,buf[x-1]);
    y=119+(sin(((i*1.1)*3.14)/180)*(90-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
    delay(2000);
    // Draw some filled rectangles
    for (int i=1; i<6; i++)
    switch (i)
    case 1:
    myGLCD.setColor(255,0,255);
    break;
    case 2:
    break;
    case 3:
    myGLCD.setColor(0,255,0);
    break;
    case 4:
    break;
    case 5:
    break;
    myGLCD.fillRect(70+(i*20), 30+(i*20), 130+(i*20), 90+(i*20));
    delay(2000);
    // Draw some filled, rounded rectangles
    switch (i)
    case 1:
    break;
    case 2:
    break;
    case 3:
    break;
    case 4:
    break;
    case 5:
    break;
    myGLCD.fillRoundRect(190-(i*20), 30+(i*20), 250-(i*20), 90+(i*20));
    delay(2000);
    // Draw some filled circles
    switch (i)
    case 1:
    break;
    case 2:
    break;
    case 3:
    break;
    case 4:
    break;
    case 5:
    break;
    myGLCD.fillCircle(100+(i*20),60+(i*20), 30);
    delay(2000);
    // Draw some lines in a pattern
    myGLCD.setColor (255,0,0);
    for (int i=15; i<224; i+=5)
    myGLCD.drawLine(1, i, (i*1.44)-10, 224);
    for (int i=224; i>15; i-=5)
    myGLCD.drawLine(318, i, (i*1.44)-11, 15);
    myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 331-(i*1.44), 15);
    myGLCD.drawLine(318, i, 330-(i*1.44), 224);
    delay(2000);
    // Draw some random circles
    for (int i=0; i<100; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=32+random(256);
    y=45+random(146);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
    delay(2000);
    // Draw some random rectangles
    x=2+random(316);
    y=16+random(207);
    x2=2+random(316);
    y2=16+random(207);
    myGLCD.drawRect(x, y, x2, y2);
    delay(2000);
    // Draw some random rounded rectangles
    x=2+random(316);
    y=16+random(207);
    x2=2+random(316);
    y2=16+random(207);
    myGLCD.drawRoundRect(x, y, x2, y2);
    delay(2000);
    x=2+random(316);
    y=16+random(209);
    x2=2+random(316);
    y2=16+random(209);
    myGLCD.drawLine(x, y, x2, y2);
    delay(2000);
    for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(316), 16+random(209));
    delay(2000);
    myGLCD.fillScr(0, 0, 255);
    myGLCD.fillRoundRect(80, 70, 239, 169);
    myGLCD.print("That's it!", CENTER, 93);
    myGLCD.print("Restarting in a", CENTER, 119);
    myGLCD.print("few seconds...", CENTER, 132);
    myGLCD.setColor(0, 255, 0);
    myGLCD.setBackColor(0, 0, 255);
    myGLCD.print("Runtime: (msecs)", CENTER, 210);
    myGLCD.printNumI(millis(), CENTER, 225);
    delay (10000);
    لطفا لینک lcd تون رو بدید تا بشه دقیق صحبت کرد
    Feb 2016
    لینک دقیقی پیدا نکردم فقط بعد کلی سرچ کردن فهمیدم درایورش ssd1289 و مدل برد راه انداز رو نوشته tft_320qvt
    متاسفانه من نمیدونم LCD تون چه مدلیه یا پروتکل ارتباطیش چیه
    چند تا لینک براتون میزارم شاید کمک کنه بهتون :
    LCDBPV2 3.2" TFT + Touch & Arduino UNO. FAST
    3.2TFT LCD - Geeetech Wiki
    Connect 3.2 TFT LCD with SSD1289 directly to Arduino mega
    Aug 2016
    سلام کتابخونه utft کجاست دانلودش کنم میخوام lcd n96رو با اردوینو راه بندازم
    ویرایش توسط magmagmary : 08-24-2016 در ساعت 04:09 AM
    Aug 2016
    من چجوری n96 رو با اردوینو مگا 2560 راه بندازم نمیدونم یه برنامه ساده برای معرفی پایه ها میخوام
    نقل قول نوشته اصلی توسط mohadese نمایش پست ها
    میتونید با اتصال به اینترنت از طریق خود نرم افزار آردوینو دانلودش کنید.
    میشه روش شماره 1 این آموزش:
    جلسه دوازدهم: آموزش اضافه کردن کتابخانه | وبلاگ آردوینو
    کافیه اونجایی که ازتون اسم کتابخونه رو میخواد UTFT بنویسید
    من تو چند تا فروم گشتم همشون میگن میتونی با همون utft راهش بندازی
    فقط خونه پرش ممکنه مجبور بشی اسم چیپ درایورت رو تو هدر برنامه تغییر بدی
