راهنمایی در مورد ارور Adafruit_TFTLCD.cpp
In file included from C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:19:0:
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:282:33: warning: backslash and newline separated by space
#define read8inline(result) { \
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:803:0: warning: "read8" redefined
#define read8(x) x=read8fn()
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:183:0: note: this is the location of the previous definition
#define read8 read8inline
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::begin(uint16_t)':
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:401:21: warning: large integer implicitly truncated to unsigned type [-Woverflow]
hi = (d) >> 8; lo = (d); CD_DATA ; write8(hi); write8(lo); }
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\pin_magic.h:187:29: note: in expansion of macro 'writeRegister16inline'
#define writeRegister16 writeRegister16inline
C:\Users\amir\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:283:5: note: in expansion of macro 'writeRegister16'
writeRegister16(ILI9341_VCOMCONTROL1, 0x2B2B);
Sketch uses 14054 bytes (5%) of program storage space. Maximum is 253952 bytes.
Global variables use 346 bytes (4%) of dynamic memory, leaving 7846 bytes for local variables. Maximum is 8192 bytes.
سلام لطفا در مورد این ارور راهنمایی کنید . جست و جو کردم و هیچ نتیجه ای نگرفتم.
بردم arduino mega2560 هست شیلد نمایشگرمم hx8347g هست .
سورسمم به این صورته :
نقل قول:
#include <hx8347lib.h>
#include <Adafruit_TFTLCD.h>
#include <Adafruit_GFX.h>
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
// D0 connects to digital pin 8
// D1 connects to digital pin 9
// D2 connects to digital pin 2
// D3 connects to digital pin 3
// D4 connects to digital pin 4
// D5 connects to digital pin 5
// D6 connects to digital pin 6
// D7 connects to digital pin 7
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(A3, A2, A1, A0, A4);
void setup(void)
tft.reset();
tft.begin(0x7575); //
void loop(void)
for(uint8_t rotation=0; rotation<4; rotation++)
tft.setRotation(rotation);
testText();
delay(5000);
unsigned long testFillScreen()
unsigned long start = micros();
tft.fillScreen(BLACK);
tft.fillScreen(RED);
tft.fillScreen(GREEN);
tft.fillScreen(BLUE);
unsigned long testText()
tft.setCursor(0, 0);
tft.setTextColor(WHITE); tft.setTextSize(1);
//tft.println("Hello World!");
tft.setTextColor(YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(WHITE); tft.setTextSize(2.5);
tft.println("dr.mohammad");
tft.println();
tft.setTextColor(GREEN);
tft.setTextSize(4);
tft.println("himax hx8347g");
tft.setTextSize(2);
tft.println("this is a test");
tft.setTextSize(1);
tft.println("Hello World");
