من یک ماژول ساعت به دستم رسیده که DS2405 هستش. میخواستم بدونم کتابخانه براش موجوده؟ یک کد نمونه براش پیدا کردم تو سایت DFrobot که عملا مشکل داره.
کد هم اینه
#include <Wire.h>
#define RTC_Address 0x32 //RTC_Address
unsigned char date[7];
Wire.begin();
I2CWriteDate();//Write the Real-time Clock
delay(100);
while(1)
I2CReadDate(); //Read the Real-time Clock
Data_process();//Process the data
delay(1000);//延时1S
//Read the Real-time data register of SD2403
void I2CReadDate(void)
unsigned char n=0;
Wire.requestFrom(RTC_Address,7);
while(Wire.available())
date[n++]=Wire.read();
delayMicroseconds(1);
Wire.endTransmission();
//Write the Real-time data register of SD2403
void I2CWriteDate(void)
WriteTimeOn();
Wire.beginTransmission(RTC_Address);
Wire.write(byte(0));//Set the address for writing
Wire.write(0x59);//second:59
Wire.write(0x01);//minute:1
Wire.write(0x95);//hour:15:00(24-hour format)
Wire.write(0x03);//weekday:Wednesday
Wire.write(0x26);//day:26th
Wire.write(0x12);//month:December
Wire.write(0x12);//year:2012
Wire.write(0x12); //Set the address for writing
WriteTimeOff();
//The program for allowing to write to SD2400
void WriteTimeOn(void)
Wire.write(0x10);//Set the address for writing as 10H
Wire.write(0x80);//Set WRTC1=1
Wire.write(0x0F);//Set the address for writing as OFH
Wire.write(0x84);//Set WRTC2=1,WRTC3=1
//The program for forbidding writing to SD2400
void WriteTimeOff(void)
Wire.write(0x0F); //Set the address for writing as OFH
Wire.write(byte(0));//Set WRTC2=0,WRTC3=0
Wire.write(byte(0));//Set WRTC1=0
//Process the time_data
void Data_process(void)
unsigned char i;
for(i=0;i<7;i++)
if(i!=2)
date[i]=(((date[i]&0xf0)>>4)*10)+(date[i]&0x0f);
date[2]=(date[2]&0x7f);
date[2]=(((date[2]&0xf0)>>4)*10)+(date[2]&0x0f);
// Use the serial monitor to see information being transmitted
Serial.print("Sec = ");//second
Serial.print(date[0]);
Serial.print(" Min = ");//minute
Serial.print(date[1]);
Serial.print(" H = ");//hour
Serial.print(date[2]);
Serial.print(" W = ");//week
Serial.print(date[3]);
Serial.print(" D = ");//day
Serial.print(date[4]);
Serial.print(" M = ");//month
Serial.print(date[5]);
Serial.print(" Y = ");//year
Serial.print(date[6]);
Serial.println();
اگر ممکنه یک لینک از ماژ.ل ساعتتون بزارید ببینیم چیه
پروتکل ارتباطیش همون I2c هست یا چیز دیگه
بله I2C هست ولینکش هم SD2405 Real time clock Module (SKU:TOY0021) - Robot Wiki
اوکی
مشکلتون با کد چیه ؟
داده غلط بهتون میده یا اصلا داده نمیده ؟
این دیتاشیت رو مطالعه کنید:
http://www.robotshop.com/media/files...et-toy0021.pdf
خیلی کامل توضیح داده
سلام مگ مگ عزیزم. ممنون از لطفتون که همیشه سر فرصت و حوصله راهنمایی میکنید. با عرض معذرت از این ماژول سوییچ کردم رو ماژول 1307 و کتابخانهRTClib حالا مشکلی که دارم اینه که از تابع dayOfWeek() میخوام استفاده کنم ولی ارور میده به این شکل: 'class DateTime' has no member named 'dayOfWeek' و کد هم به شکل زیر هستش:
#include <Wire.h> // I2C-Bibliothek einbinden
#include "RTClib.h" // RTC-Bibliothek einbinden
RTC_DS1307 RTC; // RTC Modul
void setup(void) {
// Initialisiere I2C
Wire.begin();
// Initialisiere RTC
RTC.begin();
// Serielle Ausgabe starten
// Begrüßungstext auf seriellem Monitor ausgeben
Serial.println("Starte Datum und Zeit - blog.simtronyx.de");
// Prüfen ob RTC läuft
if (! RTC.isrunning()) {
// Aktuelles Datum und Zeit setzen, falls die Uhr noch nicht läuft
RTC.adjust(DateTime(__DATE__, __TIME__));
Serial.println("Echtzeituhr wurde gestartet und auf Systemzeit gesetzt.");
else Serial.println("Echtzeituhr laeuft bereits.");
void loop(){
DateTime now=RTC.now(); // aktuelle Zeit abrufen
show_time_and_date(now); // Datum und Uhrzeit ausgeben
delay(30000); // 30 Sekunden warten bis zur nächsten Ausgabe
// Wochentag ermitteln
String get_day_of_week(uint8_t dow){
String dows=" ";
switch(dow){
case 0: dows="So"; break;
case 1: dows="Mo"; break;
case 2: dows="Di"; break;
case 3: dows="Mi"; break;
case 4: dows="Do"; break;
case 5: dows="Fr"; break;
case 6: dows="Sa"; break;
return dows;
void show_time_and_date(DateTime datetime){
// Wochentag, Tag.Monat.Jahr
Serial.print(get_day_of_week(datetime.dayOfWeek()) );
Serial.print(", ");
if(datetime.day()<10)Serial.print(0);
Serial.print(datetime.day(),DEC);
Serial.print(".");
if(datetime.month()<10)Serial.print(0);
Serial.print(datetime.month(),DEC);
Serial.print(".");
Serial.println(datetime.year(),DEC);
// Stunde:Minute:Sekunde
if(datetime.hour()<10)Serial.print(0);
Serial.print(datetime.hour(),DEC);
Serial.print(":");
if(datetime.minute()<10)Serial.print(0);
Serial.print(datetime.minute(),DEC);
Serial.print(":");
if(datetime.second()<10)Serial.print(0);
Serial.println(datetime.second(),DEC);
