دوستان چطوری میتونم روی ایپی روم خارجی داده بنویسم یا بخونم و پاک کنم ؟
البته من خودم این کد ها رو پیدا کردم ولی این که بر چه اساس پین های ای سی رو تعریف کرده متوجه نمیشم در واقع رو هر پینی که میزنی کار میکنه
نقل قول:
Reading and writing data to 24C08 EEPROM over I2C
CC0
Datasheet for 24C08 HTTP 301 This page has been moved
WIRING
__ __
PRE -| |- VCC
NC -| |- MODE
E -| |- SCL
VSS -|_____|- SDA
PRE = Write Protect -> GROUND
NC = Not connected
E = Chip Enable Input -> first EEPROM -> GROUND for I2C addresses 0x50,0x51,0x52,0x53; second EEPROM -> 5V for I2C addresses 0x54,0x55,0x56,0x57
VSS = Ground -> GROUND
VCC = Supply Voltage -> 5V
MODE = Multibyte/Page Write Mode -> GROUND (not used here)
SCL = Serial Clock -> Analog PIN 5 (Uno)
SDA = Serial Data Address IN/OUT -> Analog PIN 4 (Uno)
#include <Wire.h> // for I2C
// variable to receive data coming from the EERPROMs
byte data_received=0;
// eeprom address array, use I2C scanner sketch to find the addresses. This array contains 2 chips with 4 device addresses (like virtual chips) each
byte chip[] = {0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57};
Serial.begin(9600); // for screen output
Wire.begin(); // waking up I2C
Serial.println("Setup finished");
void writeData(int device_address, byte memory_address, byte data)
// write one byte of data 'data' to eeprom memory address 'memory_address' to chip with I2C address 'device_address'
Wire.beginTransmission(device_address); // device address
Wire.write(memory_address ); // memory address
Wire.write(data); // data to send
Wire.endTransmission(); // end
delay(10);
byte readData(int device_address, byte memory_address)
// reads one byte of data from memory location 'memory_address' in chip at I2C address 'device_address'
byte result; // return value
Wire.write(memory_address); // memory address
Wire.requestFrom(device_address,1); // get one byte of data from device
if (Wire.available())
result = Wire.read();
return result; // return the read data byte
delay(10);
// WRITING DATA
int ascii_counter = 33; // to see something we start with the first readable character in the ASCII table which is 33 == '!'
Serial.println();
Serial.print("Writing data ");
Serial.println();
for (int a=0; a<8; a++) // loop to go through the address array of the eeprom i.e. chip[a]
for (int b=0; b<256;b++) // each chip has one byte of addressable memory
writeData(chip[a],b,ascii_counter); // writing the value ascii_counter to chip chip[a] at address b
Serial.print("chip :"); // let's see what it did
Serial.print(chip[a], HEX);
Serial.print(" address :");
Serial.print(b);
Serial.print(" value :");
Serial.println(char(ascii_counter));
ascii_counter++; // next character of ASCII table
if (ascii_counter > 126) {ascii_counter = 33;}; // ASCII characters greater 126 are not visible, go back to the first readable character at 33
Serial.println();
delay(10000); // let's wait some seconds
// READING DATA
Serial.println("Reading data...");
for (int a=0; a<8; a++) // same as above, we toogle through the 8 chips ....
Serial.print("Chip: ");
Serial.println(chip[a],HEX);
for (int b=0; b<256;b++) // and all 256 addresses in each (virtual) chip...
data_received=readData(chip[a],b); // and read the data there....
Serial.print(char(data_received)); // and print it to serial....
Serial.println(); // new line for each chip
// since the chip has only a limited number of write cycles, we don't want to write again and again. Let's end the sketch
do
delay(10000);
} while ( 1 != 0);
