موضوع: ماژول پخش فایل های صوتی hsc001
نام: HSC001-500x500.jpg
مشاهده: 180
حجم: 15.3 کیلو بایت
    DAC-OUT +
    N amplifier output
    External speakers (3W) output
    GND
    Ground
    Power Ground
    VDD
    power input
    3.3V-5.4V
    4
    DAC-OUT-
    Amplifier output negative
    5
    MUTE
    Play a sound when a low level (L)
    Mute Control
    6
    USB-DP
    USB-DP
    USB for playing and downloading music
    7
    USB-DM
    USB-DM
    8
    ADK
    button
    Multiple sets of keys ADK
    9
    TX
    UART serial data output
    TTL level (3.3V)
    10
    RX
    UART serial data input
    TTL level (3.3V)
    یک برنامه نمونه:
    byte currentSound = 0x01;
      // start serial port at 9600 bps:
      //while (!Serial) {
      //  ; // wait for serial port to connect. Needed for native USB port only
      pinMode(2, INPUT);   // digital sensor is on digital pin 2
      // put your main code here, to run repeatedly:
      if(digitalRead(2))
        delay(10000);
        Serial.write(0x7E);
        Serial.write(0x04);
        Serial.write(0x41);
        Serial.write(0x00);
        Serial.write(currentSound);
        Serial.write(0xEF);
        delay(10000);
        currentSound = currentSound + 0x01;
        if(currentSound > 3)
          currentSound = 1;
    ویرایش توسط حسن : 02-12-2018 در ساعت 03:40 AM
