نمایش نتایج: از 1 به 10 از 12
موضوع: راه اندازی برد شیلد دیتا لاگر بخش ساعت
    Nov 2016
    با سلام من یک برد uno , یک شیلد دیتا لاگر تهیه کرده ام و انها را به من وصل کردم و برنامه راه اندازی ساعت از لینک فروشگاه را بر روی ان لود کردم ولی ساعت و تاریخ بی ربط نمایش می دهد 2165/165/165 (Thursday) 165:165:85
    لطفا راهنمایی بفرمایید
    نمونه برنامه
    // Date and time functions using a DS1307 RTC connected via I2C and Wire lib
    #include "RTClib.h"
    RTC_PCF8523 rtc;
    char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
    void setup () {
    while (!Serial); // for Leonardo/Micro/Zero
    Serial.begin(57600);
    if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
    if (! rtc.initialized()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
    void loop () {
    DateTime now = rtc.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(" (");
    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now + TimeSpan(7,12,30,6));
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    Serial.println();
    Serial.println();
    delay(3000);
    لینک شیلد دیتا لاگرhttp://shop.aftabrayaneh.com/Arduino...=ASC&limit=100
    ویرایش توسط faridb : 12-04-2016 در ساعت 07:27 AM
    Oct 2016
    دوست عزیز این سورس که شما اپلود کردین مال ساعت i2c میباشد .من فکر نکم این سورس راهانداز باشه
    Nov 2016
    من فقط بخش ساعت این شیلد را می خواهم راه اندازی کنم و این کد مربوط به لینک سایت فروشگاه است .
    اگر برنامه و یا تنظیم خاصی دارد لطفا راه نمایی بفرمایید
    Oct 2016
    صبر کنید تا ببنم میتوانم چ کمکی بکنم
    Oct 2016
    ببینید جواب میده یا نه
    / /Date and time functions using a DS1307 RTC connected via I2C and Wire lib
    #include "RTClib.h"
    #if defined(ARDUINO_ARCH_SAMD)
    // for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
       #define Serial SerialUSB
    #endif
    RTC_PCF8523 rtc;
    void setup () {
    #ifndef ESP8266
    #endif
        while (1);
    void loop () {
        Serial.print('/');
        Serial.print('/');
        Serial.print(" (");
        Serial.print(") ");
        Serial.print(':');
        Serial.print(':');
        Serial.println();
        Serial.print('/');
        Serial.print('/');
        Serial.print(' ');
        Serial.print(':');
        Serial.print(':');
        Serial.println();
        Serial.println();
        delay(3000);
    [/QUOTE]
    ویرایش توسط mohammadali : 12-04-2016 در ساعت 08:46 AM
    Nov 2016
    سلام کد را لود کردم این پیغام خطا را میده
    Arduino: 1.6.13 (Windows 7), Board: "Arduino/Genuino Uno"
    O:\farid\arduino\saat\saat.ino:4:20: fatal error: RTClib.h: No such file or directory
    #include "RTClib.h"
    compilation terminated.
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    Nov 2016
    کتابخانه ار سی تی وجود نداشت دانلود کردم و کپی کردم خطاب برنامه درست شد ولی برنامه را که لود کردم همان پیغام اولیه را میده:
    2125/145/0 (Thursday) 1:1:1
    since midnight 1/1/1970 = 1470594765s = 17020d
    now + 7d + 30s: 2016/8/15 7:2:51
    Oct 2016
    نقل قول نوشته اصلی توسط faridb نمایش پست ها
    خوب عزیز من شما همه کارا رو کردی برو تو کتابخونه RTClib و گذینه DS1307 یک بار اپلود کن تا تایم روی ماژول تنظیم بشه با pc بعد درست نشون میده بهت ساعت وتاریخ دقیق
    البته یکسری کد هات درست نیستند از نظر من یک بار طبق تصویر کتابخونه ds1307 اپ کن و برو سریال ببین چطوریه برای دیدن سایز بزرگ روی عکس کلیک کنید
نام: Untitled.jpg
مشاهده: 126
حجم: 63.5 کیلو بایت
    Nov 2016
    با تشکر از پیگیری شما
    بعد همه نوع تست بالاخره در همون مثالها گزینه softrtc جواب داد
    // Date and time functions using just software, based on millis() & timer
    #include <Arduino.h>
    #include <Wire.h> // this #include still required because the RTClib depends on it
    #include "RTClib.h"
    #endif
    RTC_Millis rtc;
    void setup () {
    rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
    void loop () {
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.println();
    Serial.print(" seconds since 1970: ");
    Serial.println(now.unixtime());
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.println();
    Serial.println();
    delay(3000);
    Nov 2016
    سلام من برد یونو و شیلد دیتا لاگر و ال سی دی کلید دار را وصل کردم و برنامه زیر را روی ان لود کردم
    //Sample using LiquidCrystal library
    #include <LiquidCrystal.h>
    #include "RTClib.h"
    #endif
    RTC_Millis rtc;
    LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
    // define some values used by the panel and buttons
    int lcd_key = 0;
    int adc_key_in = 0;
    #define btnRIGHT 0
    #define btnUP 1
    #define btnDOWN 2
    #define btnLEFT 3
    #define btnSELECT 4
    #define btnNONE 5
    // read the buttons
    int read_LCD_buttons()
    adc_key_in = analogRead(0); // read the value from the sensor
    // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
    // we add approx 50 to those values and check to see if we are close
    if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
    // For V1.1 us this threshold
    if (adc_key_in < 50) return btnRIGHT;
    if (adc_key_in < 250) return btnUP;
    if (adc_key_in < 450) return btnDOWN;
    if (adc_key_in < 650) return btnLEFT;
    if (adc_key_in < 850) return btnSELECT;
    // For V1.0 comment the other threshold and use the one below:
    return btnNONE; // when all others fail, return this...
    lcd.begin(16, 2); // start the library
    //lcd.setCursor(0,0);
    // lcd.print("Push the buttons"); // print a simple message
    //lcd.print("farid bazmandegan");
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.println();
    lcd.setCursor(0,0);
    lcd.print(now.year(), DEC);
    lcd.print("/");
    lcd.print(now.month(), DEC);
    lcd.print("/");
    lcd.print(now.day(), DEC);
    lcd.setCursor(1,1);
    lcd.print(now.hour(), DEC);
    lcd.print(":");
    lcd.print(now.minute(), DEC);
    lcd.print(":");
    lcd.print(now.second(), DEC);
    و ساعت و تاریخ راروی ال سی دی و ترمینال نمایش می دهد ولی مشکل اینجاست که وقتی تغذیه از برد یوتنو جدا می شود بعد از وصل دوباره تاریخ و ساعت دوباره به همان زمان و تاریخ کامپایل کردن برنامه بر می گردد
    چطور می شود این مشکل را حل کرد که ساعت و تاریخ تنظیم شده تغییر نکندد با تشکر
