// include the library code:
#include <LiquidCrystal.h>
#include "DHT.h"
#define DHTPIN 2 // what digital pin we're connected to
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
// تعیین این که نمایشگر به چه پایه هایی از بردمون وصل هستش
// LiquidCrystal(rs, rw, enable, d4, d5, d6, d7)
LiquidCrystal lcd(11,10,9,4,5,6,7);
lcd.println("DHT11 testing!");
dht.begin();
//تعیین تعداد سطر و ستون های نمایشگرمون
lcd.begin(20, 4);
//تعیین موقعیت نمایش گر برا نمایش اطلاعات
lcd.setCursor(3,1);
// نمایش یه متن رشته ای
lcd.print("Wellcome");
delay(3000);
lcd.clear();
lcd.print("WATER CREATOR");
delay(3000);
lcd.clear();
lcd.autoscroll();
lcd.setCursor(10,0);
for(int i=0 ; i<=9 ; i++)
lcd.print(i);
delay(500);
delay(2000);
lcd.clear();
lcd.noAutoscroll();
lcd.print(i);
delay(500);
// Wait a few seconds between measurements.
delay(2500);
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);// temperature in F
lcd.print("Humidity:");
lcd.print(h);
lcd.print(" %\t");
lcd.print("Temperature: ");
lcd.print(t);
lcd.print(" *C ");
lcd.print(f);
lcd.print(" *F\t");
lcd.print("Heat index: ");
// lcd.print(hic);
// lcd.print(" *C ");
// lcd.print(hif);
//lcd.println(" *F");
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
lcd.print("Failed to read from DHT sensor!");
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);// if false shows C if true shows F
