نمایش نتایج: از 1 به 10 از 107
Like Tree36 لایک
    کد کامل sim800L
    #include <SoftwareSerial.h>
    SoftwareSerial SIM900(2, 3);
    #define GSMReset 5
      gsmPower();
      gsmConfig();
      commandDetect();
      smsProcess();
    void gsmConfig() {
      pinMode(GSMReset, OUTPUT);
    void showSms() {
      char incoming_char = 0;
      if (SIM900.available() > 0)
    void smsProcess() {
        if (incoming_char == 'H')
          delay(10);
    void gsmPower() {
      digitalWrite(GSMReset, HIGH);
      delay(10);
      digitalWrite(GSMReset, LOW);
      delay(100);
      delay(7000);
      SIM900.println(cmd);
      delay(t);
      readSerial();
    void readSerial() {
      while (SIM900.available())
        Serial.write(SIM900.read());
      Serial.println("Dialing...");
      delay(2000);
    void ensms()
      delay(2000);
    void farsisms()
      delay(2000);
    void commandDetect() {
      if (Serial.available() > 0)
        char data = Serial.read();
        switch (data)
            break;
          case 'e' : ensms();
            break;
          case 'f' : farsisms();
            break;
    Feb 2016
    کد کامل sim800l
    #include <softwareserial.h>
    softwareserial sim900(2, 3);
    #define gsmreset 5
      serial.begin(9600); // for serial monitor
      sim900.begin(9600); // for gsm shield
      gsmpower();
      gsmconfig();
      commanddetect();
      smsprocess();
    void gsmconfig() {
      pinmode(gsmreset, output);
      sendcommand("at+cmgf=1\r", 100); // set sms mode to text
      sendcommand("at+cnmi=2,2,0,0,0\r", 100);
      sendcommand("at+cfun=1", 2000);
      sendcommand("at+creg?", 1000);
      serial.println("the end of config process");
      serial.println("ensert\n 'd' for dial \n 'e' for english sms \n 'f' for farsi sms");
    void showsms() {
      if (sim900.available() > 0)
        incoming_char = sim900.read(); //get the character from the cellular serial port.
        Serial.print(incoming_char); //print the incoming character to the terminal.
    void smsprocess() {
        if (incoming_char == 'h')
          delay(10);
          serial.print("horaaaaaaaaaaaaaaaaaaay");
    void gsmpower() {
      serial.println("turning gsm on");
      digitalwrite(gsmreset, high);
      delay(10);
      digitalwrite(gsmreset, low);
      delay(100);
      delay(7000);
      serial.println("config process...");
    void sendcommand(string cmd, int t)
      sim900.println(cmd);
      delay(t);
      readserial();
    void readserial() {
      while (sim900.available())
        serial.write(sim900.read());
    void dialnumber(string number) {
      serial.println("dialing...");
      sendcommand("atd" + number + ";", 100);
      serial.println("end of dial process");
      delay(2000);
    void ensms()
      serial.println("sending sms");
      sendcommand("at+cscs=\"ira\"", 200);
      sendcommand("at+cmgf=1", 200);
      sendcommand("at+csmp=17,167,0,0", 200);
      sendcommand("at+cmgs=\"09331424592\"", 500);
      sendcommand("salam\r\n aftabrayaneh !\x1a", 0);
      serial.println("end of english sms process");
      delay(2000);
    void farsisms()
      sendcommand("at+cscs=\"hex\"", 100);
      sendcommand("at+cmgf=1", 100);
      sendcommand("at+csmp=17,167,0,8", 100);
      sendcommand("at+cmgs=\"+09331424592\"", 500);
      sendcommand("0633064406270645060c002006220641062a0627062800200631062706cc062706460647\x1a", 0);
      serial.println("end of persian sms process");
      delay(2000);
    void commanddetect() {
      if (serial.available() > 0)
        char data = serial.read();
        switch (data)
          case 'd' : Dialnumber("09331424592");
            break;
          case 'e' : Ensms();
            break;
          case 'f' : Farsisms();
            break;
    مهندس جان سلام دستتون درد نکنه با این کد تونستم شماره بگیرم و اس ام اس انگلیسی ارسال کنم ولی دریافت اس ام باز هم جواب نداد. کد رو که مرور میکمردم متوجه شدم که تو تابع دریافت اس ام اس از هیچ at کامندی استفاده نشده . دلیل خاصی داره؟
    بله چون کامندهای کانفیگ توی یه تابع دیگه نوشته شده
    Feb 2016
    بله دوست عزیز متوجه شدم تو این چند روز که غیبت داشتین. اخرش اینکه با کمک اقای تنها تونستیم دریافت اس ام اس رو راه بندازیم و با استفاده از همون کد شمارو تغییر دادم که دریافت دستور از این طریق هم میسر باشه.
    مخلص کلام اینکه از هردو نفر بابت حمایت و همکاری و همفکری سپاسگزارم. محبتتون به هیچ وجه فراموش نخواهد شد.
    کد دریافت sms من فقط نمایش رد کنسول بود و پردازش نداشت.
    موفق باشید
    Mar 2016
    من تونستم روی بادریت 115200 جواب OK بگیرم اما نمیتونم تماس بگیرم یا اس ام اس بدم
    زنگ هم که میزنه به سیمکارت زنگ میخوره ولی روی سریال فقط مینویسه Ringing
    میشه راهنمایی کنید که چطور میتونم تماس بگیرم یا اس ام اس بفرستم؟ ممنون
    Oct 2014
    با این دستور می توانید زنگ بزنید:
    Atd09199999999;
    کافیه با دستور ارسال سریال واسه ماژول بفرستی
    نقل قول نوشته اصلی توسط mohammad pc نمایش پست ها
    من تونستم روی بادریت 115200 جواب ok بگیرم اما نمیتونم تماس بگیرم یا اس ام اس بدم
    زنگ هم که میزنه به سیمکارت زنگ میخوره ولی روی سریال فقط مینویسه ringing
    نیایش دارند و نمایش ندارند
    حیا دارند و ریا ندارند
    رسم دارند و اسم ندارند…
    سلام از کدهای صفحه قبل من استفاده کن
    کد رو آپلود کن و پین های softwareserial رو هم رعایت کن
    توی توابع مربوط به زنگ و اس ام اس شماره مطلوب خودت رو قرار بده .
    Feb 2017
    sim800l.println("AT+CLIP=1");// enable caller id این. اضافه کن
    Apr 2016
    کد کامل sim800L
    #define GSMReset 5
      gsmPower();
      gsmConfig();
      commandDetect();
      smsProcess();
    void gsmConfig() {
    void showSms() {
    void smsProcess() {
          delay(10);
    void gsmPower() {
      delay(10);
      delay(100);
      delay(7000);
      delay(t);
      readSerial();
    void readSerial() {
      delay(2000);
    void ensms()
      delay(2000);
    void farsisms()
      delay(2000);
        switch (data)
            break;
          case 'e' : ensms();
            break;
            break;
    سلام پایه دو و سه رو به tx rx ماژول سیم 800 وصل کردم و 5 رو به ریستش اما درست بعد از ارسال d یا E ,f گیر میکنه حتی tx rx جاشونم عوض کزذم ایا مشکلی بنظرتون میرسه؟
