نمایش نتایج: از 1 به 6 از 6
موضوع: مشکل با شیلد sim900 gsm/gprs
    Oct 2015
    ولتاژ پایه ها هم با اداپتور و هم با usb به ترتیب 4.75 و 4.95 ولت هست
    این هم نمونه کد من
    #include <softwareserial.h>
    // en: String buffer for the gprs shield message
    string msg = string("");
    // en: Set to 1 when the next gprs shield message will contains the sms message
    int smscontentflag = 0;
    //control pins of relay.
    Int relay_a=4;
    int relay_b=5;
    int relay_c=6;
    int relay_d=7;
    // en: Code pin of the sim card (if applied)
    //string sim_pin_code = string( "xxxx" );
    serial.begin(19200); // the gprs baud rate
    // initialize pins
    pinmode( 4, output );
    pinmode( 5, output );
    pinmode( 6, output );
    pinmode( 7, output );
    digitalwrite( 4, low );
    digitalwrite( 5, low );
    digitalwrite( 6, low );
    digitalwrite( 7, low );
    serial.println( "at+cmgf=1" );
    delay(200);
    char serialinbyte;
    if(serial.available())
    serialinbyte = (unsigned char)serial.read();
    delay(5);
    // en: Program also listen to the gprs shield message.
    // en: If the message ends with <cr> then process the message
    if( serialinbyte == 13 ){
    // en: Store the char into the message buffer
    processgprsmsg();
    if( serialinbyte == 10 ){
    // en: Skip line feed
    else {
    // en: Store the current character in the message string buffer
    msg += string(serialinbyte);
    // en: Make action based on the content of the sms.
    // notice than sms content is the result of the processing of several gprs shield messages.
    Void processsms( string sms ){
    if( sms.indexof("1") >= 0 ){
    digitalwrite( relay_a, high );
    serial.println("at+cmgd=1,4\r");
    if( sms.indexof("3") >= 0 ){
    digitalwrite( relay_b, high );
    if( sms.indexof("5") >= 0 ){
    digitalwrite( relay_c, high );
    if( sms.indexof("7") >= 0 ){
    digitalwrite( relay_d, high );
    if( sms.indexof("2") >= 0 ){
    digitalwrite( relay_a, low );
    if( sms.indexof("4") >= 0 ){
    digitalwrite( relay_b, low );
    if( sms.indexof("6") >= 0 ){
    digitalwrite( relay_c, low );
    if( sms.indexof("8") >= 0 ){
    digitalwrite( relay_d, low );
    else {
    // en: Request text mode for sms messaging
    void gprstextmodesms(){
    void gprsreadsmsstore( string smsstorepos ){
    serial.print( "at+cmgr=" );
    serial.println( smsstorepos );
    // en: Clear the gprs shield message buffer
    void cleargprsmsg(){
    msg = "";
    // en: Interpret the gprs shield message and act appropiately
    void processgprsmsg() {
    if( msg.indexof( "call ready" ) >= 0 ){
    // serial.println( "*** gprs shield registered on mobile network ***" );
    gprstextmodesms();
    // en: Unsolicited message received when getting a sms message
    if( msg.indexof( "+cmti" ) >= 0 ){
    // serial.println( "*** sms received ***" );
    // en: Look for the coma in the full message (+cmti: "sm",6)
    // in the sample, the sms is stored at position 6
    int ipos = msg.indexof( "," );
    string smsstorepos = msg.substring( ipos+1 );
    // serial.print( "sms stored at " );
    // serial.println( smsstorepos );
    // en: Ask to read the sms store
    gprsreadsmsstore( smsstorepos );
    // en: Sms store readed through uart (result of gprsreadsmsstore request)
    if( msg.indexof( "+cmgr:" ) >= 0 ){
    // en: Next message will contains the body of sms
    smscontentflag = 1;
    // en: Following lines are essentiel to not clear the flag!
    Cleargprsmsg();
    return;
    // en: +cmgr message just before indicate that the following grps shield message
    // (this message) will contains the sms body
    if( smscontentflag == 1 ){
    // serial.println( "*** sms message content ***" );
    // serial.println( msg );
    // serial.println( "*** end of sms message ***" );
    processsms( msg );
    cleargprsmsg();
    // en: Always clear the flag
    smscontentflag = 0;
    نقل قول نوشته اصلی توسط mehdin نمایش پست ها
    این هم نمونه کد من
    ببین یه تست بگیر
    چک کردی ببینی کامندات میرسن یا نه ؟
    مثلا چک کن اگه at رو فرستادی و ok گرفت مثلا ledروشن کنه
    کد رو سبک کن و بریز
    با این کار چک می کنی که اصلا کامندا اوکی هستن یا نه ؟
    اگه at رو گرفت یعنی یه جای کد داره گیج میزنه که البته بازم عجیبه
    حالا فعلا اینو تست کن
    Feb 2016
    این هم نمونه کد من
    مهدی جان سلام مطمينی این کد کار میکنه؟
    این کد رای ایشون جواب نداده
    شما sim900 دارید؟
