Size: 40.8 * 20 * 38mm
Weight: 55g
Speed: 4.8V@0.20sec/60°
6.0V@0.19sec/60°
Torque: 4.8V@13kg-cm
6.0V@15kg-cm
Voltage: 4.8V-7.2V
No-load operating current: 120mA
Stall Operating Current: 1450mA
Pulse response time: ≤5usec
Angular deviation: error gyrus 0 degrees, around the 45 ° error ≤3 °.
Gears: 5 Metal Gear group
Cable Length: 300mm
Interface Specification: JR / FP General.
Uses: 1:10 and 1: 8 level sports car, SUV, truck, monster truck, climbing car, robot, robots, remote control boat, -90 grade methanol for 50 fixed-wing aircraft and fixed 26cc-50cc gasoline wing aircraft model
The standard is 90 ° 180 ° servo can also function as long as the change with the pulse signal corresponding to the 500-1500-2500 angle -90 degrees to + 90 degrees. Therefore, the robot enthusiasts to
Said servo This undoubtedly has great appeal! !
Servo has three lines defined:
Dark gray: GND
Red: VCC 4.8-7.2V
Orange Line: pulse input
