نمایش نتایج: از 1 به 10 از 67
Like Tree9 لایک
موضوع: ماژول آر اف آی دی pn532 nfc / rfid با قابلیت خواندن و نوشتن
    Nov 2016
    کدت داره یه جا گیر می کنه .
    باید خط به خط بری جلو ببینی کجا داره گیر می کنه.
    کدی که من میگم رو آپلود کن ببین TEST Print رو برات چاپ می کنه یا نه !
    #include <Wire.h>
    #include <PN532_I2C.h>
    #include <PN532.h>
    #include <NfcAdapter.h>
    PN532_I2C pn532i2c(Wire);
    PN532 nfc(pn532i2c);
    void setup(void) {
      Serial.begin(115200);
      Serial.println("Hello!");
      nfc.begin();
      Serial.println("TEST Print!");
      uint32_t versiondata = nfc.getFirmwareVersion();
      if (! versiondata) {
        Serial.print("Didn't find PN53x board");
        while (1); // halt
      // Got ok data, print it out!
      Serial.print("Found chip PN5"); Serial.println((versiondata >> 24) & 0xFF, HEX);
      Serial.print("Firmware ver. "); Serial.print((versiondata >> 16) & 0xFF, DEC);
      Serial.print('.'); Serial.println((versiondata >> 8) & 0xFF, DEC);
      // Set the max number of retry attempts to read from a card
      // This prevents us from waiting forever for a card, which is
      // the default behaviour of the PN532.
      nfc.setPassiveActivationRetries(0xFF);
      // configure board to read RFID tags
      nfc.SAMConfig();
      Serial.println("Waiting for an ISO14443A card");
    void loop(void) {
      boolean success;
      uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
      uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
      // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
      // 'uid' will be populated with the UID, and uidLength will indicate
      // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
      success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
      if (success) {
        Serial.println("Found a card!");
        Serial.print("UID Length: "); Serial.print(uidLength, DEC); Serial.println(" bytes");
        Serial.print("UID Value: ");
        for (uint8_t i = 0; i < uidLength; i++)
          Serial.print(" 0x"); Serial.print(uid[i], HEX);
        Serial.println("");
        // Wait 1 second before continuing
        // PN532 probably timed out waiting for a card
        Serial.println("Timed out waiting for a card");
    اگه چاپ کنه یعنی nfc.begin رو رد می کنه و تو به دست آوردن ورژن میمونه .
    اگر رد نکنه یعنی تو nfc.begin میمونه .
    به احتمال زیاد تو ورژن می مونه .
    یه تست بگیر
    پینهای i2c ات رو درست وصل کردی دیگه
    جا به جا بزنی کار نمی کنه
    آقا دسته شما درد نکنه فهمیدم مشکل کجا بود
    Jan 2017
    نقل قول نوشته اصلی توسط mohammadhadi نمایش پست ها
    دوست عزیز منم این مشکل رو دارم،مشکل شما چجوری حل شد؟
    در ضمن کد بالا رو که ریختم test print رو نشون نداد!!
    Jan 2017
    نقل قول نوشته اصلی توسط agostino نمایش پست ها
    آخ آخ,پایه های vcc و gnd رو جابه جا زده بودم!!!با این کار ماژول سوخته احتمالا،درسته؟
    Sep 2015
    دوست عزیز مشکلت کجا بود؟ منم این مشکل رو دارم
