نمایش نتایج: از 1 به 3 از 3
Like Tree3 لایک
  • 2 Post By shobeir90
  • 1 Post By saee hajizade
موضوع: ماژول بلوتوث ورژن 4 NRF51822 Beacon دارای قابلیت ارتباط با اندروید / IOS
    پیرو اینکه دیتا بیشتری به این کالا اضاف کنم مشتاق بودم توضیحات زیر با دوستان به اشتراک بذارم
نام: 2016111112547.jpg
مشاهده: 329
حجم: 29.2 کیلو بایت
    Introduction
    Overview
    The NRF51822 beacon module is a portable iBeacon tag with ultra low power chipset NRF51822 and leverage BLE 4.0 technology.It has a portable case size, accurate hardware and robust firmware. It is designed for the commercial advertising and in-door location-based service.
    NRF51822 beacon broadcast 2.4GHz radio signals at regular and adjustable intervals when it is power on. It can be heard and interpreted by iOS and Android BLE devices that are equipped with many mobile apps.
    Description and Characteristics:
نام: 20160111134561536153.jpg
مشاهده: 349
حجم: 59.6 کیلو بایت
    1. Easy and rapidly to customize a casing in very low cost;
    2. UUID, Major, Minor and other parameters can be changed by customer;
    3. iBeacon with battery holder,easy test and use.
    4. Based on Nordic NRF51822 & CR2032 ,bluetooth low energy module;
    5. Support for IOS7.0 / Android 4.3 / or above;
    6. Effected range: 60M;
    7. Low energy module for battery life one years;
نام: 20160111134543594359.jpg
مشاهده: 313
حجم: 15.1 کیلو بایت
    Feature
     Built-in iBeacon firmware
     Built-in a coin battery holder
     Bluetooth low energy technology compatible
     Accurate digital RSSI
     High performance and ARM CortexTM-M0 32 bit processor  128 bit AES HW encryption
     Tested with iOS 7.0
    Applications
     Indoor navigation
     mobile payment
     in-store promotions specialist  flow analysis
    iBeacon Descriptions
     Run standalone as iBeacon, External host is not required.
     Application for advertisement and location.
     Support customize your own iBeacon configuration including UUID etc.
     Built in JTAG port for customized other application firmware as a standalone system.
    Electrical Characteristics
نام: 20160111134682128212.jpg
مشاهده: 325
حجم: 20.8 کیلو بایت
    مرجع
    Be Good
    Apr 2017
    آیا اپلیکیشن یا روشی برای تغییر UUID , Major , Minor این بیکن ها وجود داره؟
    تو توضیحات گفته شده که میشه تغییر داد اما چطور؟
    در مورد این ( UUID , Major , Minor ) قسمت که فرمودید اطلاعی ندارم
