فکر می کنم شما هدر کد رو مطالعه نکردید!
کد:int latchpin = 5;
int clockpin = 7;
int datapin = 6;
float b = 0;
int c = 0;
float d = 0;
int e = 0;
int speed = 300; // used to control speed of counting
int segdisp[10] = {3,159,37,13,153,73,65,27,1,9 };
int digits[]= {128,64,32,16,8,4,2,1};
pinMode(latchpin, OUTPUT);
pinMode(clockpin, OUTPUT);
pinMode(datapin, OUTPUT);
digitalWrite(latchpin, LOW);
shiftOut(datapin, clockpin, LSBFIRST, 0); // clears the right display
shiftOut(datapin, clockpin, LSBFIRST, 0); // clears the left display
digitalWrite(latchpin, HIGH);
setDigit(3,1);
// setDigit(1,5);
// setDigit(2,0);
delay(10);
void setDigit(int dig, int character)
shiftOut(datapin, clockpin, LSBFIRST, segdisp[character]);
shiftOut(datapin, clockpin, LSBFIRST, digits[dig]);
void shoop()
// Count up
for (int z=0; z<100; z++)
if (z<10)
shiftOut(datapin, clockpin, LSBFIRST, segdisp[z]); // sends the digit down the serial path
shiftOut(datapin, clockpin, LSBFIRST, 255); // sends a blank down the serial path to push the digit to the right
else if (z>=10)
d=z%10; // find the remainder of dividing z by 10, this will be the right-hand digit
c=int(d); // make it an integer, c is the right hand digit
b=z/10; // divide z by 10 - the whole number value will be the left-hand digit
e = int(b); // e is the left hand digit
digitalWrite(latchpin, LOW); // send the digits down to the shift registers!
shiftOut(datapin, clockpin, LSBFIRST, segdisp[c]);
shiftOut(datapin, clockpin, LSBFIRST, segdisp[e]);
delay(speed);
delay(2000);
// Count down
for (int z=99; z>=0; z--)
if (z<10)
else if (z>=10)
delay(speed);
delay(2000);
