نوشته اصلی توسط
faridb
سلام من برد یونو و شیلد دیتا لاگر و ال سی دی کلید دار را وصل کردم و برنامه زیر را روی ان لود کردم
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
#include <Arduino.h>
#include "RTClib.h"
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
RTC_Millis rtc;
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
// For V1.1 us this threshold
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 250) return btnUP;
if (adc_key_in < 450) return btnDOWN;
if (adc_key_in < 650) return btnLEFT;
if (adc_key_in < 850) return btnSELECT;
// For V1.0 comment the other threshold and use the one below:
return btnNONE; // when all others fail, return this...
lcd.begin(16, 2); // start the library
//lcd.setCursor(0,0);
// lcd.print("Push the buttons"); // print a simple message
//lcd.print("farid bazmandegan");
Serial.begin(57600);
rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println();
lcd.setCursor(0,0);
lcd.print(now.year(), DEC);
lcd.print("/");
lcd.print(now.month(), DEC);
lcd.print("/");
lcd.print(now.day(), DEC);
lcd.setCursor(1,1);
lcd.print(now.hour(), DEC);
lcd.print(":");
lcd.print(now.minute(), DEC);
lcd.print(":");
lcd.print(now.second(), DEC);
و ساعت و تاریخ راروی ال سی دی و ترمینال نمایش می دهد ولی مشکل اینجاست که وقتی تغذیه از برد یوتنو جدا می شود بعد از وصل دوباره تاریخ و ساعت دوباره به همان زمان و تاریخ کامپایل کردن برنامه بر می گردد
چطور می شود این مشکل را حل کرد که ساعت و تاریخ تنظیم شده تغییر نکندد با تشکر
