موضوع: ارسال و دریافت مادون قرمز با اردینو
نام: a.jpg
مشاهده: 297
حجم: 94.1 کیلو بایت
    با سلام ;کسی میتونه این برنامه ادغام با برنامه nrf2401بکنه درواقع توسط این برنامه سیگنال مادون قرمز دریافت از ریموت کنترل سپس توسط nrf024 ارسال و در ان سوی دیگر بازم توسط nrf024 دریافت و در نهایت سیگنال دریافت شده به ماژول فرستنده داده و انتشار میگردد با تشکر
      /* record.ino Example sketch for IRLib2 * Illustrate how to record a signal and then play it back.
    #include <IRLibDecodeBase.h> //We need both the coding and
    #include <IRLibSendBase.h> // sending base classes
    #include <IRLib_P01_NEC.h> //Lowest numbered protocol 1st
    #include <IRLib_P02_Sony.h> // Include only protocols you want
    #include <IRLib_P03_RC5.h>
    #include <IRLib_P04_RC6.h>
    #include <IRLib_P05_Panasonic_Old.h>
    #include <IRLib_P07_NECx.h>
    #include <IRLib_HashRaw.h> //We need this for IRsendRaw
    #include <IRLibCombo.h> // After all protocols, include this
    // All of the above automatically creates a universal decoder
    // class called "IRdecode" and a universal sender class "IRsend"
    // containing only the protocols you want.
    // Now declare instances of the decoder and the sender.
    IRdecode myDecoder;
    IRsend mySender;
    // Include a receiver either this or IRLibRecvPCI or IRLibRecvLoop
    #include <IRLibRecv.h>
    IRrecv myReceiver(11); //pin number for the receiver
    // Storage for the recorded code
    uint8_t codeProtocol; // The type of code
    uint32_t codeValue; // The data bits if type is not raw
    uint8_t codeBits; // The length of the code in bits
    //These flags keep track of whether we received the first code
    //and if we have have received a new different code from a previous one.
    bool gotOne, gotNew;
    gotOne=false; gotNew=false;
    codeProtocol=UNKNOWN;
    codeValue=0;
    delay(2000);while(!Serial);//delay for Leonardo
    Serial.println(F("Send a code from your remote and we will record it."));
    Serial.println(F("Type any character and press enter. We will send the recorded code."));
    Serial.println(F("Type 'r' special repeat sequence."));
    myReceiver.enableIRIn(); // Start the receiver
    // Stores the code for later playback
    void storeCode(void) {
    gotNew=true; gotOne=true;
    codeProtocol = myDecoder.protocolNum;
    Serial.print(F("Received "));
    Serial.print(Pnames(codeProtocol));
    if (codeProtocol==UNKNOWN) {
    Serial.println(F(" saving raw data."));
    myDecoder.dumpResults();
    codeValue = myDecoder.value;
    else {
    if (myDecoder.value == REPEAT_CODE) {
    // Don't record a NEC repeat value as that's useless.
    Serial.println(F("repeat; ignoring."));
    } else {
    codeBits = myDecoder.bits;
    Serial.print(F(" Value:0x"));
    Serial.println(codeValue, HEX);
    void sendCode(void) {
    if( !gotNew ) {//We've already sent this so handle toggle bits
    if (codeProtocol == NEC) {
    codeValue ^= 0x0800;
    else if (codeProtocol == RC6,RC5,NEC) {
    switch(codeBits) {
    case 20: codeValue ^= 0x10000; break;
    case 24: codeValue ^= 0x100000; break;
    case 28: codeValue ^= 0x1000000; break;
    case 32: codeValue ^= 0x8000; break;
    gotNew=false;
    if(codeProtocol== UNKNOWN) {
    //The raw time values start in decodeBuffer[1] because
    //the [0] entry is the gap between frames. The address
    //is passed to the raw send routine.
    codeValue=(uint32_t)&(recvGlobal.decodeBuffer[1]);
    //This isn't really number of bits. It's the number of entries
    //in the buffer.
    codeBits=recvGlobal.decodeLength-1;
    Serial.println(F("Sent raw"));
    mySender.send(codeProtocol,codeValue,codeBits);
    if(codeProtocol==UNKNOWN) return;
    Serial.print(F("Sent "));
    if (Serial.available()) {
    uint8_t C= Serial.read();
    if(C=='r')codeValue=REPEAT_CODE;
    if(gotOne) {
    storeCode();
    myReceiver.enableIRIn(); // Re-enable receiver
    else if (myReceiver.getResults()) {
    myDecoder.decode();
    sendCode();
    https://github.com/cyborg5/IRLib2
    این لینک فایل کتابخانه ای برای اردینو هست میتونید از این لینک دانلود کنید در مورد مادون قرمز و بعد دانلود و از زیپ خارج کردن در قسمت libraries اردینو قرار بدید تا برای کد بالا ایراد نگیره
    ویرایش توسط farzintey : 02-05-2018 در ساعت 11:03 AM
