نمایش نتایج: از 1 به 3 از 3
موضوع: کمک درباره فریمور پرینتر سه بعدی
    Sep 2015
    من با کامپایل فریمور مرلین مشکل دارم اردواینو IDE ارور کامپایلر میده
    ارورها:
    In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Marlin.h:43:0,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\blinkm.cpp:28:
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\fastio.h:4041:4: error: #error pins for this chip not defined in arduino.h! If you write an appropriate pin definition and have this firmware work on your chip, please submit a pull request
    In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\pins_RAMPS_14_EFB.h:31:0,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\pins.h:59,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Conditionals.h:270,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Configuration_adv.h:688,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Configuration.h:1129,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Marlin.h:44,
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\pins_RAMPS_14.h:48:4: error: #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
    In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Marlin.h:64:0,
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h: In member function 'uint8_t MarlinSerial::available()':
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:116:21: error: 'rx_buffer' was not declared in this scope
    uint8_t h = rx_buffer.head;
    In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Configuration.h:42:0,
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h: In member function 'void MarlinSerial::write(uint8_t)':
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:60:33: error: 'UCSRA' was not declared in this scope
    #define M_UCSRxA SERIAL_REGNAME(UCSR,SERIAL_PORT,A) // defines M_UCSRxA to be UCSRnA where n is the serial port number
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\macros.h:31:22: note: in definition of macro 'TEST'
    #define TEST(n,b) (((n)&_BV(b))!=0)
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:51:52: note: in expansion of macro 'SERIAL_REGNAME_INTERNAL'
    #define SERIAL_REGNAME(registerbase,number,suffix) SERIAL_REGNAME_INTERNAL(registerbase,number,suffix )
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:60:18: note: in expansion of macro 'SERIAL_REGNAME'
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:123:20: note: in expansion of macro 'M_UCSRxA'
    while (!TEST(M_UCSRxA, M_UDREx))
    In file included from e:\program files\arduino\hardware\tools\avr\avr\include\avr\i o.h:99:0,
    from e:\program files\arduino\hardware\tools\avr\avr\include\avr\p gmspace.h:88,
    from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\Marlin.h:38,
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:65:32: error: 'UDRE' was not declared in this scope
    #define M_UDREx SERIAL_REGNAME(UDRE,SERIAL_PORT,)
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:123:15: note: in expansion of macro 'TEST'
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:66:31: error: 'UDR' was not declared in this scope
    #define M_UDRx SERIAL_REGNAME(UDR,SERIAL_PORT,)
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h: In member function 'void MarlinSerial::checkRx()':
    C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727 19083124242.tmp\MarlinSerial.h:132:23: error: 'rx_buffer' was not declared in this scope
    Error compiling.
    لطفا کمک کنید
    سلام:
    دوست گرامی توضیح دادم لطفاملاحظه فرمایید.
    نصب Lcd12864برروی بردهایMega2560+Ramps1.4
    شماازآخرین ورژن آردوینواستفاده کردیدوبردرافلش نکردیدطبق توضیحاتی که دادم پیش بروید بدون دادن هیچ اخطاری کامپایل وآپلودمیکنه.
    درصورتی که جواب نگرفتید https://telegram.me/Soren3DPrinterChannel در تلگرام جهت کمک به شمادرخدمت شماهستم.
    ویرایش توسط A-H-S : 09-01-2016 در ساعت 01:56 PM
    hro
    hro آنلاین نیست.
    Aug 2015
    AHS عزیز ،
    چطوری میشه برد Mega2560 رو فلش کنیم تا بتونیم از آخرین ورژن IDE استفاده کنیم ؟
