صفحه 2 از 2 نخستنخست 12
نمایش نتایج: از 11 به 12 از 12
موضوع: برنامه keypad و نمایش روی lcd
  1. #11
    Dec 2014
    کد برنامه با کتابخانه
    #include*<Keypad.h>
    #include*<LiquidCrystal.h>
    LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the library with the numbers of the interface pins
    const byte ROWS = 4; //four rows
    const byte COLS = 4; //three columns
    char keys[ROWS][COLS] = {
    **{'1','4','7','*'},
    **{'2','5','8','0'},
    **{'3','6','9','#'},
    **{'.','B','C','D'},
    byte rowPins[ROWS] = {33, 32, 31, 30}; //connect to the row pinouts of the keypad
    byte colPins[COLS] = {37, 36, 35, 34}; //connect to the column pinouts of the keypad
    *Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    int t; // motoghayer baraye neveshtan keypad roye lcd
    int t1;
    int q;
    int x;
    int v;
    int b;
    int n;
    int q1;
    int x1;
    int v1;
    int b1;
    int n1;
    void setup(){
    **Serial.begin(9600); // open serial at 9600 bps
    **lcd.begin(20, 4);
    **lcd.setCursor(4, 0);
    **lcd.print("enter ts & sh");
    **Serial.print("enter ts & sh");
    **lcd.setCursor(0,1);
    **lcd.print("TS:");
    **Serial.print("ts");
    **lcd.setCursor(0,2);
    **lcd.print("SH:");
    **Serial.print("sh");
    ***//-------------keypad------------------------
    ****t*=*3;
    ****while(t < 8){
    ****char key = keypad.getKey();
    ****if (key != NO_KEY){
    ****lcd.setCursor(t, 1);
    ****lcd.print(key);
    ****Serial.println();
    ****Serial.print(key);
    ****delay(250);
    ****if ( t==3)
    *****q=key;
    ***if (t==4){
    *****x=key;
    ****if (t==5){
    *****v=key;
    ****if (t==6){
    *****b=key;
    ****if (t==7){
    ****n=key;*
    ***t1*=3;
    **while(t1 < 8){
    ****lcd.setCursor(t1, 2);
    ****lcd.print(key);
    **delay(250);
    ***if ( t1==3)
    *****q1=key;
    ***if (t1==4){
    *****x1=key;
    ****if (t1==5){
    *****v1=key;
    ****if (t1==6){
    *****b1=key;
    ****if (t1==7){
    ****n1=key;
    *t1++;*******
    lcd.clear();
    void loop(){
    **//--------------lcd--------------------
    **lcd.setCursor(12,0);
    **lcd.print("TS:");
    **Serial.println("TS:");
    **lcd.setCursor(15,0);
    **Serial.print(q);
    **lcd.print(x);
    **Serial.print(x);
    **lcd.print(v);
    **Serial.print(v);
    **lcd.print(b);
    **Serial.print(b);
    **lcd.print(n);
    **Serial.print(n);
    **lcd.setCursor(12,1);
    **lcd.print("SH:");
    **Serial.println("sh");
    **lcd.setCursor(15,1);
    **lcd.print(q1);
    **lcd.print(x1);
    **Serial.print(x1);
    **lcd.print(v1);
    **Serial.print(v1);
    **lcd.print(b1);
    **Serial.print(b1);
    **lcd.print(n1);
    **Serial.print(n1);
  2. #12
    Dec 2014
    نقل قول نوشته اصلی توسط sepehr نمایش پست ها
    اول تمامي متغير هايي كه ازشون به عنوان انتقال استفاده كرديد ، كلمه ي volatile رو اضافه كنيد شايد درست بشه.
