نمایش نتایج: از 1 به 4 از 4
موضوع: مشکل در راه اندازی GLCD Ks0108
    Jan 2015
    سلام خدمت اساتید محترم
    من یه برد آردینو نانو دارم و یه نمایشگر ۱۲۸*۶۴ شرکت وین استار.
    طبق لینک زیر پیش رفتم
    اما مشکل کامپایل وجود داره و خطایی که میده به شرح زیر است:
    Arduino: 1.6.8 (Linux), Board: "Arduino Nano, ATmega328"
    Build options changed, rebuilding all
    In file included from /home/hamed/Desktop/Rocket/Rocket.ino:13:0:
    /home/hamed/arduino-1.6.8/libraries/ks0108/ks0108.h:32:17: error: conflicting declaration 'typedef uint8_t boolean'
     typedef uint8_t boolean;
    In file included from sketch/Rocket.ino.cpp:1:0:
    /home/hamed/arduino-1.6.8/hardware/arduino/avr/cores/arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
     typedef bool boolean;
    In file included from /home/hamed/arduino-1.6.8/hardware/arduino/avr/cores/arduino/Arduino.h:28:0,
    /home/hamed/arduino-1.6.8/libraries/ks0108/SystemFont5x7.h:41:28: error: variable 'System5x7' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t System5x7[] PROGMEM = {
    bitmaps.h:4: error: variable 'player' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t player[] PROGMEM = {
    bitmaps.h:10: error: variable 'gameover' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t gameover[] PROGMEM = {
    bitmaps.h:60: error: variable 'startup' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t startup[] PROGMEM = {
    bitmaps.h:130: error: variable 'ast1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ast1[] PROGMEM = {
    bitmaps.h:136: error: variable 'ast2' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ast2[] PROGMEM = {
    bitmaps.h:142: error: variable 'ast3' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ast3[] PROGMEM = {
    bitmaps.h:149: error: variable 'heart' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t heart [] PROGMEM = {
    bitmaps.h:156: error: variable 'bonus' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t bonus[] PROGMEM = {
    bitmaps.h:171: error: variable 'rocks' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t rocks[9][11] PROGMEM = {
    bitmaps.h:232: error: variable 'ex1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ex1 [] PROGMEM = {
    bitmaps.h:239: error: variable 'ex2' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ex2 [] PROGMEM = {
    bitmaps.h:246: error: variable 'ex3' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
     static uint8_t ex3 [] PROGMEM = {
    /home/hamed/Desktop/Rocket/Rocket.ino:83:33: warning: narrowing conversion of 'random(0l, 56l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {ROCK2,   119,    random(0, 56), random(25, 75)}  ,
    /home/hamed/Desktop/Rocket/Rocket.ino:83:49: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
    /home/hamed/Desktop/Rocket/Rocket.ino:84:33: warning: narrowing conversion of 'random(0l, 56l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {ROCK5,   119,    random(0, 56), random(25, 75)}  ,
    /home/hamed/Desktop/Rocket/Rocket.ino:84:49: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
    /home/hamed/Desktop/Rocket/Rocket.ino:85:33: warning: narrowing conversion of 'random(0l, 56l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {ROCK8,   119,    random(0, 56), random(25, 75)}  ,
    /home/hamed/Desktop/Rocket/Rocket.ino:85:49: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
    /home/hamed/Desktop/Rocket/Rocket.ino:86:33: warning: narrowing conversion of 'random(0l, 56l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {ROCK1,   119,    random(0, 56), random(25, 75)}  ,
    /home/hamed/Desktop/Rocket/Rocket.ino:86:49: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
    /home/hamed/Desktop/Rocket/Rocket.ino:280:46: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {ROCK3,   119, random(0, 56), random(25, 75)}  ,
    /home/hamed/Desktop/Rocket/Rocket.ino:281:30: warning: narrowing conversion of 'random(0l, 56l)' from 'long int' to 'char' inside { } [-Wnarrowing]
       {BONUS,   119, random(0, 56), random(25, 75)}
    /home/hamed/Desktop/Rocket/Rocket.ino:281:46: warning: narrowing conversion of 'random(25l, 75l)' from 'long int' to 'char' inside { } [-Wnarrowing]
    exit status 1
    ممنون میشم راهنمایی بفرمایین.
    Feb 2016
    منم همین مشکل رو دارم مشکل شما حل شد؟
    منم همین مشکل رو دارم اگه ممیشه کتابخونه تست شده این ال سی دی رو بذارید ؟؟؟
    Oct 2016
    منم روی همین پروژه دارم کار میکنم
    برای حل مشکل بالا باید کلمه Static فایل های پیوستی رو به Const تغییر بدین که از اون خطاها بگذره.
    اما مشکل من در کانفلیکت تعریف typdef bool boolean و typdef unit_8 boolean حل نشده.
    هر جور هم تغییر دادم یا پاکش کردم یا مثل هم کردم جواب نداد.
    من این پروژه رو با کتابخانه openglcd.h سایت الکترونیک - آموزش و پروژه های الکترونیک روی ماژول نانو و مگا تست کردم جواب داد.
    اینم لینکشه :
    آموزش نمایشگر گرافیکی ks0108 با arduino جلسه۱ - الکترونیک
    البته من دوست دارم که کتابخونه KS0108.h رو راه اندازی کنم. اگر از دوستان کسی راه حلی داشت ممنون میشیم که راهنمایی بفرمایند.
