موضوع: التراسونیک و اردینو
    التراسونیک و اردینو
    سلام ببخشید اشتباه این کد کجاست ؟؟؟
    // US-100 Ultrasonic module in GPIO mode measuring the distance of the program
    // Unplug the US-100 module jumper cap on the back.
    unsigned int EchoPin = 2; // The Arduino's the Pin2 connection to US-100 Echo / RX
    unsigned int TrigPin = 3; // The Arduino's Pin3 connected to US-100 Trig / TX
    unsigned long Time_Echo_us = 0;
    unsigned long Len_mm = 0;
    unsigned int Len_Required;
    #define buzzer 6
    int sound ;
    int key;
    //Initialize
    Serial.begin(9600); // The measurement results through the serial output to the serial port on the PC monitor
    pinMode(EchoPin, INPUT); // The set EchoPin input mode.
    pinMode(TrigPin, OUTPUT);
    pinMode(buzzer, OUTPUT);
    pinMode(12, OUTPUT); // LED
    pinMode(11, INPUT);
    // WHAT'S THE STATUS OF KEY ???
    key=digitalRead(11);
    if(key==0){Len_Required=1500}
    else if(key==1){Len_Required=500}
    // By the Trig / Pin sending pulses trigger US-100 ranging
    digitalWrite(TrigPin, HIGH); // Send pulses begin by Trig / Pin
    delayMicroseconds(50); // Set the pulse width of 50us (> 10us)
    digitalWrite(TrigPin, LOW); // The end of the pulse
    Time_Echo_us = pulseIn(EchoPin, HIGH); // A pulse width calculating US-100 returned
    if((Time_Echo_us < 60000) && (Time_Echo_us > 1))
    Len_mm = ((Time_Echo_us*34/100)/2);
    if(Len_mm <= Len_Required)
    digitalWrite(buzzer, HIGH);
    digitalWrite(12, HIGH);
    digitalWrite(buzzer, LOW)
    digitalWrite(12,LOW );
    Serial.print("Present Distance is: "); // Output to the serial port monitor
    Serial.print(Len_mm, DEC); // Output to the serial port monitor
    Serial.println("mm"); // Output to the serial port monitor
    delay(333); // Per second (1000ms) measured
    ممنون میشم اگه جواب بدید ...
    یه تعداد از سمی کالن ها رو یادتون رفته بود:
    #define buzzer 6
    int sound ;
    int key;
    //Initialize
    pinMode(11, INPUT);
    if(key==0){Len_Required=1500;}
    else if(key==1){Len_Required=500;}
    digitalWrite(buzzer, LOW);
