نمایش نتایج: از 1 به 10 از 11
موضوع: ماژول نمایشگر 12864 oled دارای ارتباط i2c
    ماژول نمایشگر 12864 OLED دارای ارتباط I2C
    کتابخانه های مورد استفاده ضمیمه شده است
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #define OLED_RESET 4
    Adafruit_SSD1306 display(OLED_RESET);
    #define NUMFLAKES 10
    #define XPOS 0
    #define YPOS 1
    #define DELTAY 2
    #define LOGO16_GLCD_HEIGHT 16
    #define LOGO16_GLCD_WIDTH  16
    static const unsigned char PROGMEM logo16_glcd_bmp[] =
    { B00000000, B11000000,
      B00000001, B11000000,
      B00000011, B11100000,
      B11110011, B11100000,
      B11111110, B11111000,
      B01111110, B11111111,
      B00110011, B10011111,
      B00011111, B11111100,
      B00001101, B01110000,
      B00011011, B10100000,
      B00111111, B11100000,
      B00111111, B11110000,
      B01111100, B11110000,
      B01110000, B01110000,
      B00000000, B00110000 };
    void setup()   {
      // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
      display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
      // init done
      // Show image buffer on the display hardware.
      // Since the buffer is intialized with an Adafruit splashscreen
      // internally, this will display the splashscreen.
      display.display();
      delay(2000);
      // Clear the buffer.
      display.clearDisplay();
      // draw a single pixel
      display.drawPixel(10, 10, WHITE);
      // Show the display buffer on the hardware.
      // NOTE: You _must_ call display after making any drawing commands
      // to make them visible on the display hardware!
      display.display();
      delay(2000);
      // draw many lines
      testdrawline();
      display.display();
      delay(2000);
      // draw rectangles
      testdrawrect();
      display.display();
      delay(2000);
      // draw multiple rectangles
      testfillrect();
      display.display();
      delay(2000);
      // draw mulitple circles
      testdrawcircle();
      display.display();
      delay(2000);
      // draw a white circle, 10 pixel radius
      display.fillCircle(display.width()/2, display.height()/2, 10, WHITE);
      display.display();
      delay(2000);
      testdrawroundrect();
      delay(2000);
      testfillroundrect();
      delay(2000);
      testdrawtriangle();
      delay(2000);
      testfilltriangle();
      delay(2000);
      // draw the first ~12 characters in the font
      testdrawchar();
      display.display();
      delay(2000);
      // draw scrolling text
      testscrolltext();
      delay(2000);
      // text display tests
      display.setTextSize(1);
      display.setTextColor(WHITE);
      display.setCursor(0,0);
      display.println("Hello, world!");
      display.setTextColor(BLACK, WHITE); // 'inverted' text
      display.println(3.141592);
      display.setTextSize(2);
      display.print("0x"); display.println(0xDEADBEEF, HEX);
      display.display();
      delay(2000);
      // miniature bitmap display
      display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
      display.display();
      delay(1);
      // invert the display
      display.invertDisplay(true);
      display.invertDisplay(false);
      // draw a bitmap icon and 'animate' movement
      testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
    void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
      uint8_t icons[NUMFLAKES][3];
      // initialize
      for (uint8_t f=0; f< NUMFLAKES; f++) {
        icons[f][XPOS] = random(display.width());
        icons[f][YPOS] = 0;
        icons[f][DELTAY] = random(5) + 1;
        Serial.print("x: ");
        Serial.print(icons[f][XPOS], DEC);
        Serial.print(" y: ");
        Serial.print(icons[f][YPOS], DEC);
        Serial.print(" dy: ");
        Serial.println(icons[f][DELTAY], DEC);
      while (1) {
        // draw each icon
          display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, WHITE);
        display.display();
        delay(200);
        // then erase it + move it
          display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, BLACK);
          // move it
          icons[f][YPOS] += icons[f][DELTAY];
          // if its gone, reinit
          if (icons[f][YPOS] > display.height()) {
            icons[f][YPOS] = 0;
    void testdrawchar(void) {
      for (uint8_t i=0; i < 168; i++) {
        if (i == '\n') continue;
        display.write(i);
        if ((i > 0) && (i % 21 == 0))
          display.println();
      display.display();
      delay(1);
    void testdrawcircle(void) {
      for (int16_t i=0; i<display.height(); i+=2) {
        display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
        display.display();
        delay(1);
    void testfillrect(void) {
      uint8_t color = 1;
      for (int16_t i=0; i<display.height()/2; i+=3) {
        // alternate colors
        display.fillRect(i, i, display.width()-i*2, display.height()-i*2, color%2);
        display.display();
        delay(1);
        color++;
    void testdrawtriangle(void) {
      for (int16_t i=0; i<min(display.width(),display.height())/2; i+=5) {
        display.drawTriangle(display.width()/2, display.height()/2-i,
                         display.width()/2-i, display.height()/2+i,
                         display.width()/2+i, display.height()/2+i, WHITE);
        display.display();
        delay(1);
    void testfilltriangle(void) {
      uint8_t color = WHITE;
      for (int16_t i=min(display.width(),display.height())/2; i>0; i-=5) {
        display.fillTriangle(display.width()/2, display.height()/2-i,
        if (color == WHITE) color = BLACK;
        else color = WHITE;
        display.display();
        delay(1);
    void testdrawroundrect(void) {
      for (int16_t i=0; i<display.height()/2-2; i+=2) {
        display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, WHITE);
        display.display();
        delay(1);
    void testfillroundrect(void) {
        display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, color);
        else color = WHITE;
        display.display();
        delay(1);
    void testdrawrect(void) {
      for (int16_t i=0; i<display.height()/2; i+=2) {
        display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
        display.display();
        delay(1);
    void testdrawline() {
      for (int16_t i=0; i<display.width(); i+=4) {
        display.drawLine(0, 0, i, display.height()-1, WHITE);
        display.display();
        delay(1);
      for (int16_t i=0; i<display.height(); i+=4) {
        display.drawLine(0, 0, display.width()-1, i, WHITE);
        display.display();
        delay(1);
      delay(250);
        display.drawLine(0, display.height()-1, i, 0, WHITE);
        display.display();
        delay(1);
      for (int16_t i=display.height()-1; i>=0; i-=4) {
        display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
        display.display();
        delay(1);
      delay(250);
      for (int16_t i=display.width()-1; i>=0; i-=4) {
        display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
        display.display();
        delay(1);
        display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
        display.display();
        delay(1);
      delay(250);
        display.drawLine(display.width()-1, 0, 0, i, WHITE);
        display.display();
        delay(1);
        display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
        display.display();
        delay(1);
      delay(250);
    void testscrolltext(void) {
      display.setCursor(10,0);
      display.println("scroll");
      display.display();
      delay(1);
      display.startscrollright(0x00, 0x0F);
      delay(2000);
      display.stopscroll();
      display.startscrollleft(0x00, 0x0F);
      delay(2000);
      display.startscrolldiagright(0x00, 0x07);
      delay(2000);
      display.startscrolldiagleft(0x00, 0x07);
      delay(2000);
    Oct 2016
    با سلام و خسته نباشید
    نکته 1 لطفا طریقه سیم بندی این ماژول رو هم اظافه کنین
    من یکی خریدم 6 تا سیم داره GND,VCC,SCL,SDA,RST,D/C
    ولی وقتی با I2CScanner تست کردم هیچ ماژولی پیدا نکرد
    ایا اون دوتا سیم دیگه رو هم باید به طریقی ازشون استفاده کنم؟؟؟
    ظاهرا یه مدل 7 سیمه هم داره که سیماش اینطوریه
    GND,VCC,D0,D1,RST,DC,CS
    یه توضیح هم راجع به این مدل ارائه می کنین؟؟
    نکته 2 این ماژول ها فقط 3.3 ولتی هستن روی برد برای خودشون رگولاتور دارن پس ترجیحا از 3.3 استفاده کنیم بهتره
    نقل قول نوشته اصلی توسط nia_trap نمایش پست ها
    این که پین d/c داره یه توهم بوجود میاره که ارتباطش i2c نباشه . و این که با کد I2CScanner هم بهش آدرسی اختصاص نداده این باور رو قوی می کنه.
    یقینا باید از اون دو تا پین دیگه (ریست و DC ) استفاده کنید.
    کلا وقتی تعداد پینهای مورد نیازش از SCL و SDA فراتر بره دیگه نمیشه گفت که با i2c راه اندازی میشه حتی با وجود این که این دو تا اسم رو استفاده کرده باشه .
    باید دید رگولاتور چجوری تو مدار قرار گرفته .
    اگر پیشنهاد خودش 3.3 هست فقط 3.3 بهش بدید
    سلام.
    لطفا عنایت کنید که این نمایشگر پین ریست (oled_reset) ندارد، اگر به عکس آن در سایت فروشگاه هم مراجعه کنید این موضوع واضح می شود: فقط ۴ پین دارد:vcc, gnd, scl, sda
    Oct 2017
    برنامه کامپایل نمیشه و خطای زیر رو میده چرا؟؟؟
    Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    C:\Users\ATC\AppData\Local\Temp\arduino_modified_s ketch_377262\sketch_oct12a.ino:2:26: fatal error: Adafruit_GFX.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board Arduino/Genuino Mega or Mega 2560.
    Feb 2017
    نقل قول نوشته اصلی توسط mohammadbager نمایش پست ها
    exit status 1
    کتابخونه رو در آردوینو نصب نکردید اما صدا زدید .
    Oct 2017
    میشه آموزش کد نویسی برای این نوع نمایشگر رو هم بزارید ؟؟
    May 2015
    سلام، بلاخره 3.3 ولت هستندیا 5 ولت؟ در فروشگاه نوشته تا 6 ولت هم میشه بهش ولتاژ داد!
    و اینکه ایا مقاومت پول آپ باید بذاریم واسه دو تا پایه دیتا؟
    ویرایش توسط pedram032 : 11-15-2017 در ساعت 09:17 AM
    Jan 2015
    نقل قول نوشته اصلی توسط pedram032 نمایش پست ها
    من این ماژول رو با یک باطری سکه ای cr2032 که ولتاژش ۳ولت بیشتر نیست راه اندازی کردم. شما هر ماژولی رو که میخوای راه اندازی کنی و اطمینان به ولتاژ ورودیش نداری از ۳.۳ ولت شروع کن.
    May 2017
    سلام چگونه از 128*64 به 64x48 تغییر بدم؟
