نمایش نتایج: از 1 به 5 از 5
  • 1 Post By dm800vpr
موضوع: راهنمایی درباره نحوه کار با ماژول سنسور تشخیص آتش و شعله - سنسور مادون قرمز
    May 2014
    لطفا نحوه کار با ماژول سنسور تشخیص آتش و شعله - سنسور مادون قرمز را همراه با یک کد نمونه قرار دهید. در اینترنت چیزی براش پیدا نکردم.
    مدیر اصلی
    Aug 2012
    //You may copy, alter and reuse this code in any way you like but please leave reference to HobbyComponents.com in your comments if you redistribute this code.
    //This code is modified by Ahlskog Niki & Borgström Anders
    //SENSOR PINOUT:
    PIN 1: Analogue out
    PIN 2: Ground
    PIN 3: +5V
    PIN 4: Digital out
    #define FLAME_DETECT_ANA A0 // Select the input pin for the flame detectors analogue output.
    #define FLAME_DETC_DIO 2 // Select the input pin for the flame detectors digital output.
    int led = 8; // Select the input pin for the led
    void setup() // Initialize serial and DIO
    Serial.begin(9600); // Setup the serial port for displaying the status of the sensor
    pinMode(led, OUTPUT);
    pinMode(FLAME_DETC_DIO, INPUT); // Configure the DIO pin the sensors digital output will be connected to
    void loop() // Main program loop
    Serial.print("Sensor Value: "); // Read the sensors analogue output and send it to the serial port
    Serial.print(analogRead(FLAME_DETECT_ANA));
    if (digitalRead(FLAME_DETC_DIO)) // Read the status of the sensors digital output and if it is high then send an alert to the UART and the led is lighten
    Serial.println(" FLAME DETECTED!");
    digitalWrite(led, HIGH);
    digitalWrite(led, LOW);
    }else // Otherwise the there is no alert and the led is shut down
    Serial.println();
    Oct 2015
    من کد رو به صورت زیر عوض میکنم
    //You may copy, alter and reuse this code in any way you like but please leave reference to HobbyComponents.com in your comments if you redistribute this code. //This code is modified by Ahlskog Niki & Borgström Anders //SENSOR PINOUT: #define FLAME_DETECT_ANA A0 // Select the input pin for the flame detectors analogue output. #define FLAME_DETC_DIO 2 // Select the input pin for the flame detectors digital output. int led = 8; // Select the input pin for the led void setup() // Initialize serial and DIO { Serial.begin(9600); // Setup the serial port for displaying the status of the sensor pinMode(led, OUTPUT); pinMode(FLAME_DETC_DIO, INPUT); // Configure the DIO pin the sensors digital output will be connected to } void loop() // Main program loop { Serial.print("Sensor Value: "); // Read the sensors analogue output and send it to the serial port Serial.print(analogRead(FLAME_DETECT_ANA)); delay(1000); if (!digitalRead(FLAME_DETC_DIO)) // Read the status of the sensors digital output and if it is high then send an alert to the UART and the led is lighten { Serial.println(" FLAME DETECTED!"); digitalWrite(led, HIGH); delay(1000); digitalWrite(led, LOW); }else // Otherwise the there is no alert and the led is shut down { Serial.println(); digitalWrite(led, LOW); } }
    دلیلش اینه ماژول سایت فقط D0 داره و این کد برای A0 D0 نوع دیگری 4 پایه ماژول هست نه 3 پایه
    در نتیجه همیشه flame detected میده
    که من یه delay اضافه کردم و قسمت digitalRead(FLAME_DETC_DIO) رو not کردم
    توضیحات تکمیلی
    How it works: The flame sensor is very sensitive to IR wavelength at 760 nm ~ 1100 nm light. Analog output (A0): Real-time output voltage signal on the thermal resistance. Digital output (D0): When the temperature reaches a certain threshold, the output high and low signal threshold adjustable via potentiometer
    Jul 2016
    سلام من میخواستم سنسور تشخیص شعله و سنسور تشخیص گاز کربن مونواکسیدmq-7رو ترکیب کنم که با هم کار کنن ولی کداشو نتونستم با هم اجرا کنم اگه میشه کدشو برام بفرستین یا در سایت قرار بدین
    نقل قول نوشته اصلی توسط parsa_79 نمایش پست ها
    اینو تست بگیرید
    int flame = A0 , gas = 3;
      pinMode(gas, INPUT);
      Serial.println(gasData());
      Serial.println(flameData());
    int  gasData() {
      int data = analogRead(gas);
      return data;
    int flameData() {
      int data = digitalRead(flame);
      return data;
