نمایش نتایج: از 1 به 9 از 9
  • 1 Post By مینا67
موضوع: ماژول نمایشگر 1.8 اینچی - دارای ارتباط spi و درایور st7735r
    ماژول نمایشگر 1.8 اینچی - دارای ارتباط SPI و درایور ST7735R
    سیم بندی:
    Arduino
    LCD
    5V
    VCC
    GND
    GND
    3V
    LED+
    GND
    LED-
    10
    CS
    9
    A0
    8
    RST
    11
    SDA
    13
    SCL
    نمونه کد آردوینو :
    #include <Adafruit_GFX.h>    // Core graphics library
    #include <Adafruit_ST7735.h> // Hardware-specific library
    #include <SPI.h>
    // For the breakout, you can use any 2 or 3 pins
    // These pins will also work for the 1.8" TFT shield
    #define TFT_CS     10
    #define TFT_RST    8  // you can also connect this to the Arduino reset
                          // in which case, set this #define pin to 0!
    #define TFT_DC     9
    Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
    float p = 3.1415926;
    void setup(void) {
      Serial.print("Hello! ST7735 TFT Test");
      // Use this initializer if you're using a 1.8" TFT
      tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
      // Use this initializer (uncomment) if you're using a 1.44" TFT
      //tft.initR(INITR_144GREENTAB);   // initialize a ST7735S chip, black tab
      Serial.println("Initialized");
      uint16_t time = millis();
      tft.fillScreen(ST7735_BLACK);
      time = millis() - time;
      Serial.println(time, DEC);
      delay(500);
      // large block of text
      testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST7735_WHITE);
      // tft print function!
      tftPrintTest();
      delay(4000);
      // a single pixel
      tft.drawPixel(tft.width()/2, tft.height()/2, ST7735_GREEN);
      delay(500);
      // line draw test
      testlines(ST7735_YELLOW);
      delay(500);
      // optimized lines
      testfastlines(ST7735_RED, ST7735_BLUE);
      delay(500);
      testdrawrects(ST7735_GREEN);
      delay(500);
      testfillrects(ST7735_YELLOW, ST7735_MAGENTA);
      delay(500);
      testfillcircles(10, ST7735_BLUE);
      testdrawcircles(10, ST7735_WHITE);
      delay(500);
      testroundrects();
      delay(500);
      testtriangles();
      delay(500);
      mediabuttons();
      delay(500);
      Serial.println("done");
      tft.invertDisplay(true);
      delay(500);
      tft.invertDisplay(false);
      delay(500);
    void testlines(uint16_t color) {
      for (int16_t x=0; x < tft.width(); x+=6) {
        tft.drawLine(0, 0, x, tft.height()-1, color);
      for (int16_t y=0; y < tft.height(); y+=6) {
        tft.drawLine(0, 0, tft.width()-1, y, color);
        tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
        tft.drawLine(tft.width()-1, 0, 0, y, color);
        tft.drawLine(0, tft.height()-1, x, 0, color);
        tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
        tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
        tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
    void testdrawtext(char *text, uint16_t color) {
      tft.setCursor(0, 0);
      tft.setTextColor(color);
      tft.setTextWrap(true);
      tft.print(text);
    void testfastlines(uint16_t color1, uint16_t color2) {
      for (int16_t y=0; y < tft.height(); y+=5) {
        tft.drawFastHLine(0, y, tft.width(), color1);
      for (int16_t x=0; x < tft.width(); x+=5) {
        tft.drawFastVLine(x, 0, tft.height(), color2);
    void testdrawrects(uint16_t color) {
        tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
    void testfillrects(uint16_t color1, uint16_t color2) {
      for (int16_t x=tft.width()-1; x > 6; x-=6) {
        tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
        tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
    void testfillcircles(uint8_t radius, uint16_t color) {
      for (int16_t x=radius; x < tft.width(); x+=radius*2) {
        for (int16_t y=radius; y < tft.height(); y+=radius*2) {
          tft.fillCircle(x, y, radius, color);
    void testdrawcircles(uint8_t radius, uint16_t color) {
      for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
        for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
          tft.drawCircle(x, y, radius, color);
    void testtriangles() {
      int color = 0xF800;
      int t;
      int w = tft.width()/2;
      int x = tft.height()-1;
      int y = 0;
      int z = tft.width();
      for(t = 0 ; t <= 15; t+=1) {
        tft.drawTriangle(w, y, y, x, z, x, color);
        x-=4;
        y+=4;
        z-=4;
        color+=100;
    void testroundrects() {
      int color = 100;
      int i;
      int t;
      for(t = 0 ; t <= 4; t+=1) {
        int x = 0;
        int y = 0;
        int w = tft.width()-2;
        int h = tft.height()-2;
        for(i = 0 ; i <= 16; i+=1) {
          tft.drawRoundRect(x, y, w, h, 5, color);
          x+=2;
          y+=3;
          w-=4;
          h-=6;
          color+=1100;
        color+=100;
    void tftPrintTest() {
      tft.setTextWrap(false);
      tft.setCursor(0, 30);
      tft.setTextColor(ST7735_RED);
      tft.setTextSize(1);
      tft.println("Hello World!");
      tft.setTextColor(ST7735_YELLOW);
      tft.setTextSize(2);
      tft.setTextColor(ST7735_GREEN);
      tft.setTextSize(3);
      tft.setTextColor(ST7735_BLUE);
      tft.setTextSize(4);
      tft.print(1234.567);
      delay(1500);
      tft.setTextColor(ST7735_WHITE);
      tft.setTextSize(0);
      tft.setTextSize(1);
      tft.print(p, 6);
      tft.println(" Want pi?");
      tft.println(" ");
      tft.print(8675309, HEX); // print 8,675,309 out in HEX!
      tft.println(" Print HEX!");
      tft.println(" ");
      tft.println("Sketch has been");
      tft.println("running for: ");
      tft.setTextColor(ST7735_MAGENTA);
      tft.print(millis() / 1000);
      tft.print(" seconds.");
    void mediabuttons() {
      // play
      tft.fillRoundRect(25, 10, 78, 60, 8, ST7735_WHITE);
      tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_RED);
      delay(500);
      // pause
      tft.fillRoundRect(25, 90, 78, 60, 8, ST7735_WHITE);
      tft.fillRoundRect(39, 98, 20, 45, 5, ST7735_GREEN);
      tft.fillRoundRect(69, 98, 20, 45, 5, ST7735_GREEN);
      delay(500);
      // play color
      tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_BLUE);
      delay(50);
      // pause color
      tft.fillRoundRect(39, 98, 20, 45, 5, ST7735_RED);
      tft.fillRoundRect(69, 98, 20, 45, 5, ST7735_RED);
      // play color
      tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_GREEN);
    کتابخانه های مورد نیاز
    Jan 2017
    Unhappy lcd
    سلام من طبق سیم بندی وبرنامه شما عمل میکنم ولی فقط یه نور سفید میاد مشکل چی میتونه باشه؟
    نقل قول نوشته اصلی توسط reza_for97 نمایش پست ها
    دوست عزیز کد و سیم بندی تست شده هست
    یک بار سیم بنیدتون رو مجدد تست کنید
    ممکنه سیمهاتون قطعی داشته باشه
    Feb 2017
    سلام وقت بخیر برای آردوئینو مگا سیم بندی چگونه تغییر میکنه؟
    کد رو بخونید متوجهش میشید
    Feb 2017
    چجوری میشه هم از sd و هم از ال سی دی همزمان استفاده کرد؟ با توجه به اینکه هر دو spi میخان و برد mega یک سری spi داره
    Jan 2018
    ما از این LCD استفاده کرده ایم:
نام: 2_QryT13VUre.jpg
مشاهده: 166
حجم: 39.8 کیلو بایت
    و این سیم بندی را بکار برده ایم:
نام: unotft__N6ib65wiAQ.jpg
مشاهده: 246
حجم: 24.3 کیلو بایت
    سپس کتابخانه TFT.h را دانلود کردیم از طریق خود اردیانو و درست جواب گرفتیم. پین dc ذکر شده در برنامه های این کتابخانه همان A0 است.
    از مثال های این کتابخانه استفاده کنید و ال سی دی خود را تست نمایید
