درود درباره برنامه نویسی این مازول کمک کنید از ابتدا
درمورد کد نویسی هم این کد برای sim800L نوشته شده روی C هم باید جواب بده .
#include <SoftwareSerial.h>
SoftwareSerial SIM800(D2, D1 , 128);
#define GSMReset D3
  SIM800.begin(9600); // for GSM shield
  gsmPower();
  gsmConfig();
  dialNumber() ;
  commandDetect();
void gsmConfig() {
  sendCommand("ATZ", 100);
  sendCommand("AT+CMGD=1,4", 200);
  dtmfActive();
  anwerCall();
  Serial.println("Ensert\n 'd' for dial \n 'e' for english sms \n 'f' for farsi sms \n 'h' for HttpRequest \n 's' for Send2Pachube  ");
void showSms() {
  char incoming_char = 0;
  if ( SIM800.available() > 0)
    incoming_char =  SIM800.read(); //Get the character from the cellular serial port.
void smsProcess() {
    if (incoming_char == 'A')
      delay(10);
      if (incoming_char == 'd')
        delay(10);
void gsmPower() {
  pinMode(GSMReset, OUTPUT);
  digitalWrite(GSMReset, HIGH);
 // delay(1100);
  //digitalWrite(GSMReset, LOW);
 // delay(4000);
  Serial.println("Start config process...");
  SIM800.println(cmd);
  readSerial();
  delay(t);
void readSerial( ) {
  while (SIM800.available())
    Serial.write(SIM800.read());
void dialNumber() {
  Serial.println("Dialing...");
  sendCommand("ATD09177102643;", 100);
  delay(2000);
void ensms()
  sendCommand("AT+CSCS=\"GSM\"", 200);
  sendCommand("AT+CMGS=\"09177102643\"", 500);
  sendCommand("Salam\n manam !\x1A", 500);
  Serial.println("Englisg SMS Sent");
void farsisms()
  Serial.println("Persian SMS Sent");
void commandDetect() {
  if (Serial.available() > 0)
    char data = Serial.read();
    switch (data)
      case 'd' :
        dialNumber();
        break;
      case 'e' : ensms();
        break;
      case 'f' : farsisms();
        break;
      case 'h':
        SubmitHttpRequest();
        break;
      case 's':
        Send2Pachube();
        break;
void SubmitHttpRequest()
  sendCommand("AT+CSQ", 100);
  sendCommand("AT+CGATT?", 100);
  sendCommand("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"", 1000); //setting the SAPBR, the connection type is using gprs
  sendCommand("AT+SAPBR=3,1,\"APN\",\"CMNET\"", 4000); //setting the APN, the second need you fill in your local apn server
  sendCommand("AT+SAPBR=1,1", 2000); //setting the SAPBR, for detail you can refer to the AT command mamual
  sendCommand("AT+HTTPINIT", 2000); //init the HTTP request
  sendCommand("AT+HTTPPARA=\"URL\",\"www.google.com.hk\"", 1000); // setting the httppara, the second parameter is the website you want to access
  sendCommand("AT+HTTPACTION=0", 10000); //submit the request
  sendCommand("AT+HTTPREAD", 300); // read the data from the website you access
  sendCommand("", 100);
  delay(2000);
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
  sendCommand("AT+CGATT?", 1000);
  sendCommand("AT+CSTT=\"CMNET\"", 1000); //start task and setting the APN,
  sendCommand("AT+CIICR", 3000); //bring up wireless connection
  sendCommand("AT+CIFSR", 2000); //get local IP adress
  sendCommand("AT+CIPSPRT=0", 3000);
  sendCommand("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"", 2000); //start up the connection
  sendCommand("AT+CIPSEND", 4000); //begin send data to remote server
  String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
  String moisture = "1242";//you can replace these four variable to the real sensor data in your project
  String temperature = "30";//
  String barometer = "60.56";//
  sendCommand("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"", 500); //here is the feed you apply from pachube
  sendCommand(": {},\"headers\": {\"X-PachubeApiKey\":", 500); //in here, you should replace your pachubeapikey
  sendCommand(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0", 500); //pachubeapikey
  sendCommand("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc", 500); //pachubeapikey
  sendCommand("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":", 500);
  sendCommand(" {\"version\": \"1.0.0\",\"datastreams\": ", 500);
  sendCommand("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},", 500);
  sendCommand("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},", 500);
  sendCommand("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},", 500);
  sendCommand("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}", 500);
  SIM800.println(); ((char)26); //sending
  delay(5000);
  SIM800.println();
  sendCommand("AT+CIPCLOSE", 100); //close the connection
  delay(2000);
void dtmfActive() {
  sendCommand("AT+DDET=1", 200);
void anwerCall() {
  sendCommand("ATS0=3", 200);
void blinkd16(){
  pinMode(16,OUTPUT);
  digitalWrite(16,HIGH);
  delay(100);
  digitalWrite(16,LOW);
    delay(100);
