نمایش نتایج: از 1 به 5 از 5
موضوع: کمک در پروژه هویه رومیزی
    Dec 2016
    سلام من دارم رویه یه پروژه هویه رومیزی کار میکنم
    این برناممه و ارور
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    رو میده و میخوام قسمت 7segment رو تغییر بدم و با lcd نمایش بده میتونین کمکم کنین با تشکر
    اینم برنامه
    #include <PID_v1.h>
    //This array contains what segments need to be turned on to display numbers 0-9
    byte const digits[] = {
    B00111111, B00000110, B01011011, B01001111, B01100110, B01101101, B01111101, B00000111, B01111111, B01101111
    int digit_common_pins[] = {A3, A4, A5}; //Common pins for the triple 7-Segment LED display
    int max_digits = 3;
    int current_digit = max_digits - 1;
    unsigned long updaterate = 500; //Change how fast the display updates. No lower than 500
    unsigned long lastupdate;
    int temperature = 0;
    //Define Variables we'll be connecting to
    double Setpoint, Input, Output;
    //Define the aggressive and conservative Tuning Parameters
    double aggKp = 4, aggKi = 0.2, aggKd = 1;
    double consKp = 1, consKi = 0.05, consKd = 0.25;
    //Specify the links and initial tuning parameters
    PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
    DDRD = B11111111; // sets Arduino pins 0 to 7 as outputs
    for (int y = 0; y < max_digits; y++)
    pinMode(digit_common_pins[y], OUTPUT);
    //We do not want to drive the soldering iron at 100% because it may burn, so we set it to about 85% (220/255)
    myPID.SetOutputLimits(0, 220);
    myPID.SetMode(AUTOMATIC);
    lastupdate = millis();
    Setpoint = 0;
    //Read temperature
    Input = analogRead(0);
    //Transform the 10bit reading into degrees celsius
    Input = map(Input, 0, 510, 25, 350);
    //Display temperature
    if (millis() - lastupdate > updaterate) {
    temperature = Input;
    //Read setpoint and transform it into degrees celsius(minimum 150, maximum 350)
    double newSetpoint = analogRead(1);
    newSetpoint = map(newSetpoint, 0, 1023, 150, 350);
    //Display setpoint
    if (abs(newSetpoint - Setpoint) > 3) {
    Setpoint = newSetpoint;
    temperature = newSetpoint;
    double gap = abs(Setpoint - Input); //distance away from setpoint
    if (gap < 10)
    { //we're close to setpoint, use conservative tuning parameters
    myPID.SetTunings(consKp, consKi, consKd);
    //we're far from setpoint, use aggressive tuning parameters
    myPID.SetTunings(aggKp, aggKi, aggKd);
    myPID.Compute();
    //Drive the output
    analogWrite(11, Output);
    //Display the temperature
    show(temperature);
    void show(int value) {
    int digits_array[] = {};
    boolean empty_most_significant = true;
    for (int z = max_digits - 1; z >= 0; z--) //Cycle through each digit
    digits_array[z] = value / pow(10, z); //We now take each digit from the number
    if (digits_array[z] != 0 ) empty_most_significant = false; //Do not display leading zeros
    value = value - digits_array[z] * pow(10, z);
    if (z == current_digit)
    if (!empty_most_significant || z == 0) { //Check to see that we do not have leading zeros and display the current digit
    PORTD = ~digits[digits_array[z]]; //Remove ~ for common cathode
    PORTD = B11111111;
    digitalWrite(digit_common_pins[z], HIGH);//Change to LOW for common cathode
    } else {
    digitalWrite(digit_common_pins[z], LOW);//Change to HIGH for common cathode
    current_digit--;
    if (current_digit < 0)
    current_digit = max_digits; //Start over
    میشه کم واضح تر بفرمایید ؟
    تونستید کد رو کامپیال کنید دوست عزیز؟
    Dec 2016
    شما کجاشو مشکل دارین توضیح بدم؟
    Dec 2016
    تبدیل به hex کردم و با نرم افزار دیگه ای کامپایل کردم
