کدی که باید تست کنی اینه :
به یه چیز هم دقت کنکد:#include <Bounce2.h> #include <Timer.h> int tm, i, z; int buttonPushCounter = 0; // counter for the number of button presses int buttonState = 0; // current state of the button int lastButtonState = 0; const int buttonPin = 16; // previous state of the button Timer t; Bounce debouncer = Bounce(); void setup() { pinMode(22, INPUT); //define pinMode pinMode(23, INPUT); pinMode(16, INPUT); debouncer.attach(16); debouncer.interval(5); Serial.begin(9600); delay(2000); tm = 0; } void loop() { Serial.print("press9 up,10 down"); Serial.print(tm); delay (1000); if (digitalRead(22) == LOW) { tm++; while (digitalRead(22) == HIGH); Serial.println(tm); } if (digitalRead(23) == LOW) { tm--; while (digitalRead(23) == HIGH); Serial.println(tm); } if (tm < 0) { tm = 0; } if (digitalRead( 16) == LOW) { Serial.print("you are ready..."); delay(10); tm = tm * 60 * 1000; for (i = 3; i > 0; i--) { Seial.print(i); delay(1000); } while (1) { t.update(); t.after(tm, resultTap); debouncer.update(); // read the pushbutton input pin: buttonState = debouncer.read(); Serial.print("number of button pushes: "); if (buttonState != lastButtonState) { if (buttonState == LOW) { buttonPushCounter++; Serial.println(buttonPushCounter); } delay(50); } lastButtonState = buttonState; } } } void resultTap() { t.stop(z);//timer stop Serial.print("number of result: ");//showing number of push Serial.println(buttonPushCounter); //delay(5000); }
خود تابع loop به صورت حلقه همیشگی تکرار میشه بنابراین while(1) اولیت اضافی بود
4 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
