اگر منظور شما این کد هست
اگه بخواید برای ماژول های GSM غیر اورجینال استفاده کنید باید یه سری تغییرات بدید که اگر در کدنویسی وارد نیستید بهتره برید سراغ کدهای ساده ترکد:/* SMS receiver This sketch, for the Arduino GSM shield, waits for a SMS message and displays it through the Serial port. Circuit: * GSM shield attached to and Arduino * SIM card that can receive SMS messages created 25 Feb 2012 by Javier Zorzano / TD This example is in the public domain. http://www.arduino.cc/en/Tutorial/GSMExamplesReceiveSMS */ // include the GSM library #include <GSM.h> // PIN Number for the SIM #define PINNUMBER "" // initialize the library instances GSM gsmAccess; GSM_SMS sms; // Array to hold the number a SMS is retreived from char senderNumber[20]; void setup() { // initialize serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } Serial.println("SMS Messages Receiver"); // connection state boolean notConnected = true; // Start GSM connection while (notConnected) { if (gsmAccess.begin(PINNUMBER) == GSM_READY) { notConnected = false; } else { Serial.println("Not connected"); delay(1000); } } Serial.println("GSM initialized"); Serial.println("Waiting for messages"); } void loop() { char c; // If there are any SMSs available() if (sms.available()) { Serial.println("Message received from:"); // Get remote number sms.remoteNumber(senderNumber, 20); Serial.println(senderNumber); // An example of message disposal // Any messages starting with # should be discarded if (sms.peek() == '#') { Serial.println("Discarded SMS"); sms.flush(); } // Read message bytes and print them while (c = sms.read()) { Serial.print(c); } Serial.println("\nEND OF MESSAGE"); // Delete message from modem memory sms.flush(); Serial.println("MESSAGE DELETED"); } delay(1000); }
مثلا این کد:
این کد یه نمونه هست که میاد بر اساس sms دریافتی چهار تا رله رو فعال / غیر فعال می کنهکد:// EN: String buffer for the GPRS shield message String msg = String(""); // EN: Set to 1 when the next GPRS shield message will contains the SMS message int SmsContentFlag = 0; //control pins of relay. int relay_a=4; int relay_b=5; int relay_c=6; int relay_d=7; // EN: Code PIN of the SIM card (if applied) //String SIM_PIN_CODE = String( "XXXX" ); void setup() { Serial.begin(19200); // the GPRS baud rate // Initialize PINs pinMode( 4, OUTPUT ); pinMode( 5, OUTPUT ); pinMode( 6, OUTPUT ); pinMode( 7, OUTPUT ); digitalWrite( 4, LOW ); digitalWrite( 5, LOW ); digitalWrite( 6, LOW ); digitalWrite( 7, LOW ); Serial.println( "AT+CMGF=1" ); delay(200); } void loop() { char SerialInByte; if(Serial.available()) { SerialInByte = (unsigned char)Serial.read(); delay(5); // ------------------------------------------------------------------- // EN: Program also listen to the GPRS shield message. // ------------------------------------------------------------------- // EN: If the message ends with <CR> then process the message if( SerialInByte == 13 ){ // EN: Store the char into the message buffer ProcessGprsMsg(); } if( SerialInByte == 10 ){ // EN: Skip Line feed } else { // EN: store the current character in the message string buffer msg += String(SerialInByte); } } } // EN: Make action based on the content of the SMS. // Notice than SMS content is the result of the processing of several GPRS shield messages. void ProcessSms( String sms ){ if( sms.indexOf("ona") >= 0 ){ digitalWrite( relay_a, HIGH ); } if( sms.indexOf("onb") >= 0 ){ digitalWrite( relay_b, HIGH ); } if( sms.indexOf("onc") >= 0 ){ digitalWrite( relay_c, HIGH ); } if( sms.indexOf("ond") >= 0 ){ digitalWrite( relay_d, HIGH ); } if( sms.indexOf("offa") >= 0 ){ digitalWrite( relay_a, LOW ); } if( sms.indexOf("offb") >= 0 ){ digitalWrite( relay_b, LOW ); } if( sms.indexOf("offc") >= 0 ){ digitalWrite( relay_c, LOW ); } if( sms.indexOf("offd") >= 0 ){ digitalWrite( relay_d, LOW ); } } // EN: Request Text Mode for SMS messaging void GprsTextModeSMS(){ Serial.println( "AT+CMGF=1" ); } void GprsReadSmsStore( String SmsStorePos ){ Serial.print( "AT+CMGR=" ); Serial.println( SmsStorePos ); } // EN: Clear the GPRS shield message buffer void ClearGprsMsg(){ msg = ""; } // EN: interpret the GPRS shield message and act appropiately void ProcessGprsMsg() { if( msg.indexOf( "Call Ready" ) >= 0 ){ // Serial.println( "*** GPRS Shield registered on Mobile Network ***" ); GprsTextModeSMS(); } // EN: unsolicited message received when getting a SMS message if( msg.indexOf( "+CMTI" ) >= 0 ){ // Serial.println( "*** SMS Received ***" ); // EN: Look for the coma in the full message (+CMTI: "SM",6) // In the sample, the SMS is stored at position 6 int iPos = msg.indexOf( "," ); String SmsStorePos = msg.substring( iPos+1 ); // Serial.print( "SMS stored at " ); // Serial.println( SmsStorePos ); // EN: Ask to read the SMS store GprsReadSmsStore( SmsStorePos ); } // EN: SMS store readed through UART (result of GprsReadSmsStore request) if( msg.indexOf( "+CMGR:" ) >= 0 ){ // EN: Next message will contains the BODY of SMS SmsContentFlag = 1; // EN: Following lines are essentiel to not clear the flag! ClearGprsMsg(); return; } // EN: +CMGR message just before indicate that the following GRPS Shield message // (this message) will contains the SMS body if( SmsContentFlag == 1 ){ // Serial.println( "*** SMS MESSAGE CONTENT ***" ); // Serial.println( msg ); // Serial.println( "*** END OF SMS MESSAGE ***" ); ProcessSms( msg ); } ClearGprsMsg(); // EN: Always clear the flag SmsContentFlag = 0; }
LinkBack URL
About LinkBacks
پاسخ با نقل قول
