1 لایک
Post By iranarduino
مشگل در کد نویسی سون سگمنت
با سلام خدمت
دوستان این کد رو نوشتم ولی اعداد ثابت نمیمونه روی سون سگمنت
میتونید بگید اشکال کار کجاس؟
int rclkpin = 5; // connect to pin 12 on the '595
int sclkpin = 7; // connect to pin 11 on the '595
int diopin = 6; // connect to pin 14 on the '595
int score = 0;
int THRESHOLD = 100;
int sensorPin1 = 0;
int sensorPin2 = 1;
byte val1 = 0;
byte val2 = 0;
//int speed = 300; // used to control speed of counting
int segdisp[10] = {
3,
159,
37,
13,
153,
73,
65,
27,
1,
9
int digits[] = {
128,
64,
32,
16,
8,
4,
2,
pinMode(rclkpin, OUTPUT);
pinMode(sclkpin, OUTPUT);
pinMode(diopin, OUTPUT);
digitalWrite(rclkpin, LOW);
shiftOut(diopin, sclkpin, LSBFIRST, 0); // clears the right display
shiftOut(diopin, sclkpin, LSBFIRST, 0); // clears the left display
digitalWrite(rclkpin, HIGH);
val1 = analogRead(sensorPin1);
val2 = analogRead(sensorPin2);
if (val1 >= THRESHOLD) {
score += 1000;
set4Digit(score);
delay(10);
if (val2 >= THRESHOLD) {
score += 3000;
set4Digit(score);
delay(10);
void set4Digit(int di)
int a = di/1000;
int b = (di/100) - (a * 10);
int c = (di/10) - (a * 100) - (b * 10);
int d = di - (a * 1000) - (b * 100) - (c * 10);
setDigit(3, a);
setDigit(2, b);
setDigit(1, c);
setDigit(0, d);
delay(100);
void setDigit(int dig, int character) {
shiftOut(diopin, sclkpin, LSBFIRST, segdisp[character]);
shiftOut(diopin, sclkpin, LSBFIRST, digits[dig]);
