یا این یکی:
#include <String.h>
unsigned char SigQ[50];
unsigned char SigQ1[5]={'a','a','a','a','a'};
int SIGQ=0;
Serial1.begin(115200); // the GPRS baud rate
Serial.begin(115200); // the GPRS baud rate
delay(500);
// mySerial.println("AT+CPIN?"); //get the signal Quality
// delay(100);
// pinMode(9, OUTPUT);
// digitalWrite(9,LOW);
// delay(1000);
// digitalWrite(9,HIGH);
// delay(1500);
//GetSignalQuality();
for(int x=0;x<20;x++)
GetSignalQuality();
delay(800);
for(int i=0;i<26;i++)
if(SigQ[i]==58)
int j=0;
int k=0;
i++;i++;
while((SigQ[i+j])!=44)
if((SigQ[i+j]>='0'&&SigQ[i+j]<='9')) //>=48 <=57
SigQ1[j]=SigQ[i+j];
j++; //j=1
SIGQ=SigQ1[0]-'0';
if(j==2)
SIGQ=SIGQ*10+SigQ1[1]-'0';
Serial.println("");
Serial.print("SIGQ:");
Serial.println(SIGQ);
if ( Serial1.available())
Serial.write( Serial1.read());
if (SIGQ>=10)
break;
if(x==20)
Serial.print("The Signal Quality is poor!");
delay(2000);
DialVoiceCall();
//after start up the program, you can using terminal to connect the serial of gprs shield,
//if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
//if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
// GetSignalQuality();
delay(500);
if (Serial.available())
switch(Serial.read())
case 't':
SendTextMessage();
break;
case 'd':
DialVoiceCall();
break;
case 'h':
SubmitHttpRequest();
break;
case 's':
Send2Pachube();
break;
case 'q':
GetSignalQuality();
break;
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
Serial1.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
Serial1.println("AT + CMGS = \"+8613016490443\"");//send sms message, be careful need to add a country code before the cellphone number
delay(100);
Serial1.println("GSM test message!");//the content of the message
delay(100);
Serial1.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
Serial1.println();
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
Serial1.println("AT+SNFS=0");
delay(100);
Serial1.println("ATDxxxxxxxxxx;");//dial the number
//mySerial.println("ATD + +8613826558615;");//dial the number
delay(100);
Serial1.println();
///SubmitHttpRequest()
///this function is submit a http request
///attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest()
Serial1.println("AT+CSQ");
delay(100);
ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
Serial1.println("AT+CGATT?");
delay(100);
ShowSerialData();
Serial1.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\" ");//setting the SAPBR, the connection type is using gprs
ShowSerialData();
Serial1.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server
delay(4000);
ShowSerialData();
Serial1.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
delay(2000);
ShowSerialData();
Serial1.println("AT+HTTPINIT"); //init the HTTP request
delay(2000);
ShowSerialData();
Serial1.println("AT+HTTPPARA=\"URL\",\"www.google. com.hk\"");// setting the httppara, the second parameter is the website you want to access
ShowSerialData();
Serial1.println("AT+HTTPACTION=0");//submit the request
delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
//while(!mySerial.available());
ShowSerialData();
Serial1.println("AT+HTTPREAD");// read the data from the website you access
delay(300);
ShowSerialData();
Serial1.println("");
delay(100);
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
delay(100);
ShowSerialData();
Serial1.println("AT+CSTT=\"CMNET\"");//start task and setting the APN,
ShowSerialData();
Serial1.println("AT+CIICR");//bring up wireless connection
delay(300);
ShowSerialData();
Serial1.println("AT+CIFSR");//get local IP adress
delay(2000);
ShowSerialData();
Serial1.println("AT+CIPSPRT=0");
delay(3000);
ShowSerialData();
Serial1.println("AT+CIPSTART=\"tcp\",\"api.cosm.co m\",\"8081\"");//start up the connection
delay(2000);
ShowSerialData();
Serial1.println("AT+CIPSEND");//begin send data to remote server
delay(4000);
ShowSerialData();
String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
String moisture = "1242";//you can replace these four variable to the real sensor data in your project
String temperature = "30";//
String barometer = "60.56";//
Serial1.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube
delay(500);
ShowSerialData();
Serial1.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey
delay(500);
ShowSerialData();
Serial1.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey
delay(500);
ShowSerialData();
Serial1.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey
delay(500);
ShowSerialData();
Serial1.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNS sQS\"},\"body\":");
delay(500);
ShowSerialData();
Serial1.print(" {\"version\": \"1.0.0\",\"datastreams\": ");
delay(500);
ShowSerialData();
Serial1.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},");
delay(500);
ShowSerialData();
Serial1.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},");
delay(500);
ShowSerialData();
Serial1.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},");
delay(500);
ShowSerialData();
Serial1.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}");
delay(500);
ShowSerialData();
Serial1.println((char)26);//sending
delay(5000);//waitting for reply, important! the time is base on the condition of internet
Serial1.println();
ShowSerialData();
Serial1.println("AT+CIPCLOSE");//close the connection
delay(100);
ShowSerialData();
void GetSignalQuality()
Serial1.println("AT+CSQ"); //get the signal Quality
delay(100);
int k=0;
while( Serial1.available()!=0)
SigQ[k]= Serial1.read();
Serial.write(SigQ[k]);
k+=1;
void ShowSerialData()
