کد هم اینه
#include <Wire.h>
#define RTC_Address 0x32 //RTC_Address
unsigned char date[7];
Wire.begin();
I2CWriteDate();//Write the Real-time Clock
delay(100);
while(1)
I2CReadDate(); //Read the Real-time Clock
Data_process();//Process the data
delay(1000);//延时1S
//Read the Real-time data register of SD2403
void I2CReadDate(void)
unsigned char n=0;
Wire.requestFrom(RTC_Address,7);
while(Wire.available())
date[n++]=Wire.read();
delayMicroseconds(1);
Wire.endTransmission();
//Write the Real-time data register of SD2403
void I2CWriteDate(void)
WriteTimeOn();
Wire.beginTransmission(RTC_Address);
Wire.write(byte(0));//Set the address for writing
Wire.write(0x59);//second:59
Wire.write(0x01);//minute:1
Wire.write(0x95);//hour:15:00(24-hour format)
Wire.write(0x03);//weekday:Wednesday
Wire.write(0x26);//day:26th
Wire.write(0x12);//month
ecember
Wire.write(0x12);//year:2012
Wire.write(0x12); //Set the address for writing
WriteTimeOff();
//The program for allowing to write to SD2400
void WriteTimeOn(void)
Wire.write(0x10);//Set the address for writing as 10H
Wire.write(0x80);//Set WRTC1=1
Wire.write(0x0F);//Set the address for writing as OFH
Wire.write(0x84);//Set WRTC2=1,WRTC3=1
//The program for forbidding writing to SD2400
void WriteTimeOff(void)
Wire.write(0x0F); //Set the address for writing as OFH
Wire.write(byte(0));//Set WRTC2=0,WRTC3=0
Wire.write(byte(0));//Set WRTC1=0
//Process the time_data
void Data_process(void)
unsigned char i;
for(i=0;i<7;i++)
if(i!=2)
date[i]=(((date[i]&0xf0)>>4)*10)+(date[i]&0x0f);
date[2]=(date[2]&0x7f);
date[2]=(((date[2]&0xf0)>>4)*10)+(date[2]&0x0f);
// Use the serial monitor to see information being transmitted
Serial.print("Sec = ");//second
Serial.print(date[0]);
Serial.print(" Min = ");//minute
Serial.print(date[1]);
Serial.print(" H = ");//hour
Serial.print(date[2]);
Serial.print(" W = ");//week
Serial.print(date[3]);
Serial.print(" D = ");//day
Serial.print(date[4]);
Serial.print(" M = ");//month
Serial.print(date[5]);
Serial.print(" Y = ");//year
Serial.print(date[6]);
Serial.println();
