					کمک درباره فریمور پرینتر سه بعدی
 من با کامپایل فریمور مرلین مشکل دارم اردواینو IDE ارور کامپایلر میده
 ارورها:
 In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Marlin.h:43:0,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\blinkm.cpp:28:
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\fastio.h:4041:4: error: #error pins for this chip not defined in arduino.h! If you write an appropriate pin definition and have this firmware work on your chip, please submit a pull request
 In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\pins_RAMPS_14_EFB.h:31:0,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\pins.h:59,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Conditionals.h:270,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Configuration_adv.h:688,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Configuration.h:1129,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Marlin.h:44,
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\pins_RAMPS_14.h:48:4: error: #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
 In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Marlin.h:64:0,
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h: In member function 'uint8_t MarlinSerial::available()':
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:116:21: error: 'rx_buffer' was not declared in this scope
 uint8_t h = rx_buffer.head;
 In file included from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Configuration.h:42:0,
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h: In member function 'void MarlinSerial::write(uint8_t)':
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:60:33: error: 'UCSRA' was not declared in this scope
 #define M_UCSRxA SERIAL_REGNAME(UCSR,SERIAL_PORT,A) // defines M_UCSRxA to be UCSRnA where n is the serial port number
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\macros.h:31:22: note: in definition of macro 'TEST'
 #define TEST(n,b) (((n)&_BV(b))!=0)
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:51:52: note: in expansion of macro 'SERIAL_REGNAME_INTERNAL'
 #define SERIAL_REGNAME(registerbase,number,suffix) SERIAL_REGNAME_INTERNAL(registerbase,number,suffix  )
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:60:18: note: in expansion of macro 'SERIAL_REGNAME'
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:123:20: note: in expansion of macro 'M_UCSRxA'
 while (!TEST(M_UCSRxA, M_UDREx))
 In file included from e:\program files\arduino\hardware\tools\avr\avr\include\avr\i  o.h:99:0,
 from e:\program files\arduino\hardware\tools\avr\avr\include\avr\p  gmspace.h:88,
 from C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\Marlin.h:38,
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:65:32: error: 'UDRE' was not declared in this scope
 #define M_UDREx SERIAL_REGNAME(UDRE,SERIAL_PORT,)
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:123:15: note: in expansion of macro 'TEST'
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:66:31: error: 'UDR' was not declared in this scope
 #define M_UDRx SERIAL_REGNAME(UDR,SERIAL_PORT,)
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h: In member function 'void MarlinSerial::checkRx()':
 C:\Users\HAMEDH~1\AppData\Local\Temp\build20374727  19083124242.tmp\MarlinSerial.h:132:23: error: 'rx_buffer' was not declared in this scope
 Error compiling.
 لطفا کمک کنید
							سلام:
 دوست گرامی توضیح دادم لطفاملاحظه فرمایید.
 http://forum.arduino.ir/23/24/1693.html
 شماازآخرین ورژن آردوینواستفاده کردیدوبردرافلش نکردیدطبق توضیحاتی که دادم پیش بروید بدون دادن هیچ اخطاری کامپایل وآپلودمیکنه.
 درصورتی که جواب نگرفتید   https://telegram.me/Soren3DPrinterChannel    در تلگرام جهت کمک به شمادرخدمت شماهستم.
						ویرایش توسط A-H-S : 09-01-2016 در ساعت 02:56 PM
 AHS عزیز ،
 چطوری میشه برد Mega2560 رو فلش کنیم تا بتونیم از آخرین ورژن IDE استفاده کنیم ؟
