برای ارتباط با آردوینو از طریق پروتوکل محبوب TCP/IP میتونید از کد زیر استفاده کنید
این کد اطلاعات دریافتی از طریق شبکه رو به پورت سریال انتقال میده
کد:#include <SPI.h> #include <Ethernet.h> // Enter a MAC address, IP address and Portnumber for your Server below. // The IP address will be dependent on your local network: byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; IPAddress serverIP(192,168,195,214); int serverPort=8888; // Initialize the Ethernet server library // with the IP address and port you want to use EthernetServer server(serverPort); void setup() { // start the serial for debugging Serial.begin(9600); // start the Ethernet connection and the server: Ethernet.begin(mac, serverIP); server.begin(); Serial.println("Server started");//log } void loop() { // listen for incoming clients EthernetClient client = server.available(); if (client) { String clientMsg =""; while (client.connected()) { if (client.available()) { char c = client.read(); //Serial.print(c); clientMsg+=c;//store the recieved chracters in a string //if the character is an "end of line" the whole message is recieved if (c == '\n') { Serial.println("Message from Client:"+clientMsg);//print it to the serial client.println("You said:"+clientMsg);//modify the string and send it back clientMsg=""; } } } // give the Client time to receive the data delay(1); // close the connection: client.stop(); } }
LinkBack URL
About LinkBacks
پاسخ با نقل قول
