من هم یک آموزش پیدا کردم دقیقا در مورد همینه : https://arduino-info.wikispaces.com/...alRS485Example
کدهایی که استفاده کرده خیلی خیلی روون تره .
کد سمت مستر:
کد سمت سلیو :کد:#include <SoftwareSerial.h> /*-----( Declare Constants and Pin Numbers )-----*/ #define SSerialRX 10 //Serial Receive pin #define SSerialTX 11 //Serial Transmit pin #define SSerialTxControl 3 //RS485 Direction control #define RS485Transmit HIGH #define RS485Receive LOW #define Pin13LED 13 /*-----( Declare objects )-----*/ SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX /*-----( Declare Variables )-----*/ int byteReceived; int byteSend; void setup() /****** SETUP: RUNS ONCE ******/ { // Start the built-in serial port, probably to Serial Monitor Serial.begin(9600); Serial.println("YourDuino.com SoftwareSerial remote loop example"); Serial.println("Use Serial Monitor, type in upper window, ENTER"); pinMode(Pin13LED, OUTPUT); pinMode(SSerialTxControl, OUTPUT); digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver // Start the software serial port, to another device RS485Serial.begin(4800); // set the data rate }//--(end setup )--- void loop() /****** LOOP: RUNS CONSTANTLY ******/ { digitalWrite(Pin13LED, HIGH); // Show activity if (Serial.available()) { byteReceived = Serial.read(); digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit RS485Serial.write(byteReceived); // Send byte to Remote Arduino digitalWrite(Pin13LED, LOW); // Show activity delay(10); digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit } if (RS485Serial.available()) //Look for data from other Arduino { digitalWrite(Pin13LED, HIGH); // Show activity byteReceived = RS485Serial.read(); // Read received byte Serial.write(byteReceived); // Show on Serial Monitor delay(10); digitalWrite(Pin13LED, LOW); // Show activity } }//--(end main loop )---
کد:#include <SoftwareSerial.h> /*-----( Declare Constants and Pin Numbers )-----*/ #define SSerialRX 10 //Serial Receive pin #define SSerialTX 11 //Serial Transmit pin #define SSerialTxControl 3 //RS485 Direction control #define RS485Transmit HIGH #define RS485Receive LOW #define Pin13LED 13 /*-----( Declare objects )-----*/ SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // RX, TX /*-----( Declare Variables )-----*/ int byteReceived; int byteSend; void setup() /****** SETUP: RUNS ONCE ******/ { // Start the built-in serial port, probably to Serial Monitor Serial.begin(9600); Serial.println("SerialRemote"); // Can be ignored pinMode(Pin13LED, OUTPUT); pinMode(SSerialTxControl, OUTPUT); digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver // Start the software serial port, to another device RS485Serial.begin(4800); // set the data rate }//--(end setup )--- void loop() /****** LOOP: RUNS CONSTANTLY ******/ { //Copy input data to output if (RS485Serial.available()) { byteSend = RS485Serial.read(); // Read the byte digitalWrite(Pin13LED, HIGH); // Show activity delay(10); digitalWrite(Pin13LED, LOW); digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit RS485Serial.write(byteSend); // Send the byte back delay(10); digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit // delay(100); }// End If RS485SerialAvailable }//--(end main loop )---
6 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
