نمایش نتایج: از 1 به 4 از 4
موضوع: rfid+shild data logger+lcd
    میتونید از این کد الهام بگیرید برای کاری که قصد دارید انجام بدید:
    //Read And Write by Tim Tolar
    //enjoy and fell free to change code. Thanks!
    //RFID pinout
    //Reset   RST          9
    //SS      SDA          10
    //MOSI    MOSI         11
    //MISO    MISO         12
    //SCK     SCK          13
    #include <SPI.h>
    #include <MFRC522.h>
    #include <LiquidCrystal.h>   //library for lcd
    #define RST_PIN         9
    #define SS_PIN          10
    MFRC522 mfrc522(SS_PIN, RST_PIN);
    MFRC522::MIFARE_Key key;
    LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
    const int BackLight = 8;
    pinMode(BackLight, OUTPUT);
    digitalWrite(BackLight, HIGH);
    lcd.begin(16,2);
    delay(100);
    lcd.setCursor(0,0);
    lcd.println(F("Read And Write  "));
    lcd.setCursor(0,1);
    lcd.println(F("by TIM TOLAR :)  "));
    delay(2000);
    lcd.clear();
    SPI.begin();
    mfrc522.PCD_Init();
    for (byte i = 0; i < 6; i++) {
    key.keyByte[i] = 0xFF;}
    lcd.setCursor(0,0);
    lcd.println(F("Scan a MIFARE  !"));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Using key A or B!"));
    lcd.clear();
    dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
    lcd.setCursor(0,0);
    lcd.println(";)Files will be ");
    lcd.setCursor(0,1);
    lcd.println(F("writen in sector"));
    lcd.clear();
    if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
    if ( ! mfrc522.PICC_ReadCardSerial())
    return;
    lcd.begin(16,2);
    lcd.setCursor(0,0);
    lcd.println(F("Card UID:       "));
    lcd.setCursor(0,1);
    lcd.println("MIFARE 522        ");
    lcd.clear();
    dump_byte_array(mfrc522.uid.uidByte,mfrc522.uid.size);
    lcd.setCursor(0,0);
    lcd.println(F("PICC type:      "));
    lcd.setCursor(0,1);
    byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
    lcd.print(mfrc522.PICC_GetTypeName(piccType));
    if ( piccType != MFRC522::PICC_TYPE_MIFARE_MINI
    &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
    &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.println(F("only works with MIFARE."));
    return;}
    lcd.clear();
    byte sector         = 1;
    byte blockAddr      = 4;
    byte dataBlock[]    = {
            0x01, 0x02, 0x03, 0x04,
            0x05, 0x06, 0x07, 0x08,
            0x08, 0x09, 0xff, 0x0b,
            0x0c, 0x0d, 0x0e, 0x0f
    byte trailerBlock   = 7;
    byte status;
    byte buffer[18];
    byte size = sizeof(buffer);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.println(F("checking key A !"));
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
    if (status != MFRC522::STATUS_OK) {
    lcd.setCursor(0,1);
    lcd.print(F("checking failed: "));}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(mfrc522.GetStatusCodeName(status));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.println(F("Current data in sector:"));
    mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Reading data "));
    lcd.setCursor(0,1);
    lcd.print(F("from block "));
    lcd.print(blockAddr);
    lcd.clear();
    lcd.setCursor(0,0);
    status = mfrc522.MIFARE_Read(blockAddr, buffer, &size);
    lcd.setCursor(0,0);
    lcd.print(F("failed"));
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print(mfrc522.GetStatusCodeName(status));}
    lcd.setCursor(0,0);
    lcd.print(F("Data in block "));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    dump_byte_array(buffer, 16);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("singing key B..."));
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
    lcd.setCursor(0,1);
    lcd.print(F("PCD_Authenticate() failed: "));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.println(mfrc522.GetStatusCodeName(status));
    return;}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Writing data  "));
    lcd.setCursor(0,1);
    dump_byte_array(dataBlock, 16);
    lcd.clear();
    status = mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
    lcd.setCursor(0,0);
    lcd.print(F("MIFARE_Write() failed: "));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Reading data from block "));
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.println(mfrc522.GetStatusCodeName(status));}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.println(F("Checking result..."));
    byte count = 0;
    for (byte i = 0; i < 16; i++) {
    if (buffer[i] == dataBlock[i])
    count++;}
    lcd.setCursor(0,1);
    lcd.print(F("Number of bytes that match = "));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(count);
    if (count == 16) {
    lcd.setCursor(0,1);
    lcd.print(F("Success :-)"));
    } else {
    lcd.print(F("Failure, no match :-("));
    lcd.print(F("  perhaps the write didn't work properly..."));}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("thanks see you");
    digitalWrite(BackLight, LOW);
    lcd.clear();
    lcd.setCursor(0,0);
    mfrc522.PICC_HaltA();
    mfrc522.PCD_StopCrypto1();}
    void dump_byte_array(byte *buffer, byte bufferSize) {
    for (byte i = 0; i < bufferSize; i++) {
    lcd.print(buffer[i] < 0x10 ? " 0" : " ");
    رفرنس:
    arduino rfid read and write on lcd - All
    Aug 2016
    //RFID pinout
    //Reset   RST          9
    //SS      SDA          10
    //MOSI    MOSI         11
    //MISO    MISO         12
    //SCK     SCK          13
    #include <SPI.h>
    #define RST_PIN         9
    #define SS_PIN          10
    lcd.begin(16,2);
    delay(100);
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    delay(2000);
    lcd.clear();
    SPI.begin();
    mfrc522.PCD_Init();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    return;
    return;
    lcd.begin(16,2);
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    return;}
    lcd.clear();
    byte sector         = 1;
    byte blockAddr      = 4;
    byte status;
    byte buffer[18];
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    return;}
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    byte count = 0;
    count++;}
    lcd.setCursor(0,1);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(count);
    if (count == 16) {
    lcd.setCursor(0,1);
    } else {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.clear();
    lcd.setCursor(0,0);
    رفرنس:
    ممنونم ازتون
    از طریق این تیکه کد برای اسم و تاریخ ورود استفاده میکنه؟ و اینکه کتابخانه تاریخ و ساعت مگه نمی خواد؟
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.clear();
    Aug 2014
    با عرض سلام و خسته نباشید
    من در پروژه ای نیاز دارم تا اطلاعت چندین سنسور (که تقریبا تمام پایه های اردیونو رو اشغال می کنه) رو در کارت sdذخیره کنم که برای آن شیلد دیتا لاگر تهیه کردم. می خواستم بدونم می شه به منظور آزاد کردن پین های Arduino برای انتقال اطلاعات از icspدر arduino uno ، و در شیلد دیتا لاگر (بع علت نداشتن icsp جدا ) از پایه های اصلی استفاده کرد؟ (دیتا لاگر رو برد اردیونو سوار نکرد و سیم کشید)
