نمایش نتایج: از 1 به 6 از 6
موضوع: nrf24l01 usb
    Sep 2013
    یه آموزش انگلیسی پیدا کردم شاید بدردتون بخوره
    فقط نتیجه رو اعلام کنید
    Support Windows 98/Me/2000/XP/Server 2003/VISTA /
     2008/Win7 server 32 bit / 64
     Module data transmission wireless USB Series Support AT Command Set up the system!
     Note: This price does not include NRF24L01 module! !
     With a stable CH340T USB to Serial
    • Two modules are power LED indicator lights (Power always) status indicator NRF24L01 (normal detection module flashes)
    • Surveillance Built-in anti-collision procedures, harsh environment industrial control occasions.
    • Module NRF24L01 toward the web, as shown in the figure below, insert anti-system will not work, but will not burn module
    • With this module you can make the transmission distance wireless farthest range (100-1100m, depending on the use of wireless module), much higher than Bluetooth (10m) away serial transmission
     Purchase program:
     1.2 or more in this serial wireless module (NRF24L01 property)
     Experiment The communication can be made ​​between the module and the module can be many, many-to-many
     2.1 This serial wireless module (NRF24L01 property)
     You can do the experiment of communication between the computer and the microcontroller, such as single-chip wireless transmission of collected sensor data to the host computer; PC control MCU to execute multiple commands
     Parameters and commands:
     Note: All commands are case, the score should be half the width score in the state of English! !
     1, a single byte of effective transfer: 1 -31 bytes.
     The first system of 0 bytes reserved for each transmission packet size statistics; how to send serial "abc" (ASCII code 3 bytes) port, the actual transfer of "3ABC" 0 bytes on the first three, in order to receive must process to determine the actual length of the received data packet based on that number bytes.
     2, Module Baud Rate: 4800,9600,14400,19200,38400,57600,115200.
     Covers common transmission rate (baud rate factory default is 9600)
     Baud rate modification instructions: Send ASCII code [AT + baud = x (X is 1, 2, 3, 4, 5, 6, 7 Correspondent 4800, 9600, 14400, 19200, 38400, 115200 baud rate)
     Example: To change the baud rate to 115,200, then send ASCII serial debugging assistant [AT + BAUD = 7] The system responds:
     Baud rate set successfully! !
     Baud Rate: 115200
     In this case, the baud rate is 115200, serial debugging assistant needs to change to 115200 to communicate with the module.
     Note: The command must be uppercase!
     3, transfer rate NRF24L01 module: 1Mbps, 2Mbps (factory default 1Mbps)
     Baud rate setting command: Send ASCII code [AT + = speed x] (X is 1, 2 Corresponding 1Mbps, 2Mbps transmission rate)
     Such as: Change the transfer rate of 2 Mbps, then send ASCII serial debugging assistant [AT RATE + = 2] The system responds:
     The baud rate set successfully! !
     Transmission power: 0dBm
     Transfer rate: 2Mbps
     Low noise amplification gain: open
     4, NRF24L01 address configuration module: 5 address, place and address of the receiver match 0 (default 0xFF, 0xFF, 0xFF, 0xFF, 0xFF factory)
     Address Set command: Send ASCII code [AT + ADD = 0x **, ** 0x, 0x **, ** 0x, 0x ** (0x ** is set to face a comma "" It must be in English half-width point )
     Such as: Change address is 0x11, 0x22, 0x33, 0x44, 0x55, then send ASCII serial debugging assistant [AT + ADD = 0x11, 0x22, 0x33, 0x44, 0x55] The system responds:
     Defining Success Address! !
     Location Address: 0x11, 0x22, 0x33, 0x44, 0x55
     Get endpoint address 00:00 x11, 0x22, 0x33, 0x44, 0x55
     5 Survey Information System:
     Query command: Send ASCII code [? AT] The system responds:
     AT?
     Information about the system:
     Baud Rate: 115200
    Apr 2014
    خيلي ممنونم
    ولي انگار اين مال اون نيست
    در هر صورت طبقش عمل كردم باز جوابي نداد
    ميشه بفرماييد از كجا آوردين اينو
    Sep 2013
    از یه سایت ایتالیایی ترجمش کردم
    راستشو بخوای امروز خودم هم یکی از همین بردها گرفتم ولی با این دستور العمل نتیجه ای نگرفتم
    لطف کنید اگه نتیجه ای گرفتید ما رو هم در جریان بزارید
