ببین کلا برای راه اندازی این سنسور باید از اینتراپت و event اون استفاده کنی.
بنابراین کدهایی مه برای آردوینو وجود داره رو بردار تابع اینتراپتشون رو مناسب با زبان بیسیک بسکام تغییر بده .
مثلا این کد :
کد:volatile int NbTopsFan; //measuring the rising edges of the signal int Calc; int hallsensor = 2; //The pin location of the sensor void rpm () //This is the function that the interupt calls { NbTopsFan++; //This function measures the rising and falling edge of the hall effect sensors signal } // The setup() method runs once, when the sketch starts void setup() // { pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input Serial.begin(9600); //This is the setup function where the serial port is initialised, attachInterrupt(0, rpm, RISING); //and the interrupt is attached } // the loop() method runs over and over again, // as long as the Arduino has power void loop () { NbTopsFan = 0; //Set NbTops to 0 ready for calculations sei(); //Enables interrupts delay (1000); //Wait 1 second cli(); //Disable interrupts Calc = (NbTopsFan * 60 / 5.5); //(Pulse frequency x 60) / 5.5Q, = flow rate in L/hour Serial.print (Calc, DEC); //Prints the number calculated above Serial.print (" L/hour\r\n"); //Prints "L/hour" and returns a new line }
LinkBack URL
About LinkBacks
پاسخ با نقل قول
