نمایش نتایج: از 1 به 10 از 37
Like Tree13 لایک
موضوع: تنظیم رطوبت و دمای گلخانه توسط آردینو
Threaded View
  1. #30
    Jan 2016
    یه فیلم گرفتم از روش کار کردنش:
    http://s7.picofile.com/file/82383647...22004.zip.html
    #include <EEPROM.h>
    #include <Bounce2.h>
    #include <DHT.h>
    #include <LiquidCrystal.h>
    #define setBUTTON 13
    #define upBUTTON 12
    #define downBUTTON 11
    #define DHTPIN 2
    #define DHTTYPE DHT21
    Bounce set;
    Bounce up;
    Bounce down;
    DHT dht(DHTPIN, DHTTYPE);
    LiquidCrystal lcd(8, 7, 6, 5, 4, 3);
      const byte temprelay = 10, humidityrelay = 9;
      byte humiditySetpoint = 85;
      byte tempSetpoint = 20;
      unsigned long prevMillis = 0;
      unsigned long currentmillis = millis();
      static byte prevdownButton;
      static byte prevupButton;
      static byte prevsetButton;
      static byte  prevSetMode;
      byte setMode;
      lcd.begin(16, 2);
      lcd.clear();
      dht.begin();
        set.attach (setBUTTON);
        set.interval(30);
        up.attach (upBUTTON);
        up.interval(30);
        down.attach (downBUTTON);
        down.interval(30);
          pinMode (setBUTTON, INPUT_PULLUP);
          pinMode (upBUTTON, INPUT_PULLUP);
          pinMode (downBUTTON, INPUT_PULLUP);
      humiditySetpoint = EEPROM.read(0);
      tempSetpoint = EEPROM.read(1);
      set.update();
      up.update();
      down.update();
      float h = dht.readHumidity();
      float t = dht.readTemperature();
      if (isnan(h) || isnan(t)) {
        lcd.clear();
        lcd.setCursor(1,0);
        lcd.print("Failed to read ");
        lcd.setCursor(0,1);
        lcd.print("from DHT sensor!");
        delay(2000);
        lcd.clear();
        return;
      if ((t) >= tempSetpoint){
      digitalWrite (temprelay, HIGH);
           else if ((t) <= tempSetpoint-5)
           digitalWrite (temprelay, LOW);
       if ((h) >= humiditySetpoint){
       digitalWrite (humidityrelay, LOW);
           else if ((h) <=humiditySetpoint-10)
           digitalWrite (humidityrelay, HIGH);
      if ( setMode != 0) {
        if (currentmillis - prevMillis >= 10000UL) {
          setMode = 0;
          prevMillis = currentmillis;
        if (set.fell()) {
          setMode++;
        prevsetButton = setBUTTON;
      if (setMode >= 3) {
        setMode = 0;
      if (setMode != prevSetMode) {
        lcd.clear();
        prevSetMode = setMode;
      switch (setMode) {
          case 0://normal
       lcd.print("Humidity:");
       lcd.setCursor(10,0);
       lcd.print(h);
       lcd.setCursor(15,0);
       lcd.print("%");
       lcd.setCursor(1,1);
       lcd.print("Temp:");
       lcd.setCursor(7,1);
       lcd.print(t);
       lcd.setCursor(12,1);
       lcd.print(" *C ");
          break;
        case 1://edit temp
          if ('upButton' != prevupButton) {
            if (up.fell()) {
              tempSetpoint = tempSetpoint + 1;
            prevupButton = 'upButton';
          if ('downButton' != prevdownButton) {
            if (down.fell()) {
              tempSetpoint = tempSetpoint - 1;
            prevdownButton = 'downButton';
          lcd.setCursor(0, 0);
          lcd.print("Set temp:");
          lcd.setCursor(7, 1);
          lcd.print(tempSetpoint);
          lcd.setCursor(9,1);
          lcd.print("*C");
          EEPROM.write(1, tempSetpoint);
          break;
        case 2://edit humidity
            if (up.fell()) {
              humiditySetpoint = humiditySetpoint + 1;
            if (down.fell()) {
              humiditySetpoint = humiditySetpoint - 1;
          lcd.print("Set Humidity:");
          lcd.print(humiditySetpoint);
          lcd.setCursor(9,1);
          lcd.print("%");
          EEPROM.write(0, humiditySetpoint);
          break;
    ویرایش توسط cjmj : 02-11-2016 در ساعت 06:45 PM
