موضوع: ماژول درایور موتور 30 آمپر VNH2SP30 full-bridge
    معرفی پینهای ماژول
نام: VNH2SP30_SINGLE_1-500x500.jpg
مشاهده: 219
حجم: 82.3 کیلو بایت
نام: 0J5062.624.jpg
مشاهده: 167
حجم: 20.0 کیلو بایت
    Mar 2016
    سلام نحوه اتصال به آردینیو را هم قرار می دهید با یک مثال ساده برای حرکت و جهت
    تشکر
    کد PHP:
    /*  MonsterMoto Shield Example Sketch
      date: 5/24/11
      code by: Jim Lindblom
      hardware by: Nate Bernstein
      SparkFun Electronics
     License: CC-SA 3.0, feel free to use this code however you'd like.
     Please improve upon it! Let me know how you've made it better.
     This is really simple example code to get you some basic
     functionality with the MonsterMoto Shield. The MonsterMote uses
     two VNH2SP30 high-current full-bridge motor drivers.
     Use the motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
     function to get motors going in either CW, CCW, BRAKEVCC, or
     BRAKEGND. Use motorOff(int motor) to turn a specific motor off.
     The motor variable in each function should be either a 0 or a 1.
     pwm in the motorGo function should be a value between 0 and 255.
    #define BRAKEVCC 0
    #define CW   1
    #define CCW  2
    #define BRAKEGND 3
    #define CS_THRESHOLD 100
    /*  VNH2SP30 pin definitions
     xxx[0] controls '1' outputs
     xxx[1] controls '2' outputs */
    int inApin[2] = {74};  // INA: Clockwise input
    int inBpin[2] = {89}; // INB: Counter-clockwise input
    int pwmpin[2] = {56}; // PWM input
    int cspin[2] = {23}; // CS: Current sense ANALOG input
    int enpin[2] = {01}; // EN: Status of switches output (Analog pin)
    int statpin 13;
    void setup()
    pinMode(statpinOUTPUT);
    // Initialize digital pins as outputs
    for (int i=0i<2i++)
    pinMode(inApin[i], OUTPUT);
    pinMode(inBpin[i], OUTPUT);
    pinMode(pwmpin[i], OUTPUT);
    // Initialize braked
    for (int i=0i<2i++)
    digitalWrite(inApin[i], LOW);
    digitalWrite(inBpin[i], LOW);
    // motorGo(0, CW, 1023);
      // motorGo(1, CCW, 1023);
    void loop()
    motorGo(0CW1023);
    motorGo(1CCW1023);
    delay(500);
    motorGo(0CCW1023);
    motorGo(1CW1023);
    delay(500);
      if ((
    analogRead(cspin[0]) < CS_THRESHOLD) && (analogRead(cspin[1]) < CS_THRESHOLD))
    digitalWrite(statpinHIGH);
    void motorOff(int motor)
    for (int i=0i<2i++)
    analogWrite(pwmpin[motor], 0);
    /* motorGo() will set a motor going in a specific direction
     the motor will continue going in that direction, at that speed
     until told to do otherwise.
     motor: this should be either 0 or 1, will selet which of the two
     motors to be controlled
     direct: Should be between 0 and 3, with the following result
     0: Brake to VCC
     1: Clockwise
     2: CounterClockwise
     3: Brake to GND
     pwm: should be a value between ? and 1023, higher the number, the faster
     it'll go
    void motorGo(uint8_t motoruint8_t directuint8_t pwm)
      if (
    motor <= 1)
        if (
    direct <=4)
    // Set inA[motor]
    if (direct <=1)
    digitalWrite(inApin[motor], HIGH);
          else
    digitalWrite(inApin[motor], LOW);
    // Set inB[motor]
    if ((direct==0)||(direct==2))
    digitalWrite(inBpin[motor], HIGH);
          else
    digitalWrite(inBpin[motor], LOW);
    analogWrite(pwmpin[motor], pwm);
    سلام. برای درایو موتور dc استغاده کردم. 13ولت 2آمپر. اما آیسی و برد زیریش خیلی داغ میکنه. !!!
    کسی به این مشکل برنخورده
