صفحه 4 از 4 نخستنخست ... 234
نمایش نتایج: از 31 به 34 از 34
Like Tree25 لایک
موضوع: همکاری جهت ترجمه های پروژه های آردوینو
  1. #31
    Apr 2013
    سلام و وقت بخیر خدمت مدیر سایت
    من میخواستم پروژه های زیر رو ترجمه کنم.لطفا بررسی کنید.مشکلی نیست؟
    BareMinimum: The bare minimum of code needed to start an Arduino sketch.
    Blink: Turn an LED on and off.
    DigitalReadSerial: Read a switch, print the state out to the Arduino Serial Monitor.
    AnalogReadSerial: Read a potentiometer, print it's state out to the Arduino Serial Monitor.
    Fade: Demonstrates the use of analog output to fade an LED.
    ReadAnalogVoltage : Reads an analog input and prints the voltage to the serial monitor
    igital
    Blink Without Delay: blinking an LED without using the delay() function.
    Button: use a pushbutton to control an LED.
    Debounce: read a pushbutton, filtering noise.
    Button State Change: counting the number of button pushes.
    Input Pullup Serial: Demonstrates the use of INPUT_PULLUP with pinMode().
    Tone: play a melody with a Piezo speaker.
    Pitch follower: play a pitch on a piezo speaker depending on an analog input.
    Simple Keyboard: a three-key musical keyboard using force sensors and a piezo speaker.
    Tone4: play tones on multiple speakers sequentially using the tone() command
    AnalogInOutSerial: read an analog input pin, map the result, and then use that data to dim or brighten an LED.
    Analog Input: use a potentiometer to control the blinking of an LED.
    AnalogWriteMega: fade 12 LEDs on and off, one by one, using an Arduino Mega board.
    Calibration: define a maximum and minimum for expected analog sensor values.
    Fading: use an analog output (PWM pin) to fade an LED.
    Smoothing: smooth multiple readings of an analog input.
    LED Bar Graph: how to make an LED bar graph.
    Row Column Scanning: how to control an 8x8 matrix of LEDs.
    StringAdditionOperator: add strings together in a variety of ways.
    StringAppendOperator: append data to strings.
    StringCaseChanges: change the case of a string.
    StringCharacters: get/set the value of a specific character in a string.
    StringComparisonOperators: compare strings alphabetically.
    StringConstructors: how to initialize string objects.
    StringIndexOf: look for the first/last instance of a character in a string.
    StringLength & StringLengthTrim: get and trim the length of a string.
    StringReplace: replace individual characters in a string.
    StringStartsWithEndsWith: check which characters/substrings a given string starts or ends with.
    StringSubstring: look for "phrases" within a given string.
    If Statement (Conditional): how to use an if statement to change output conditions based on changing input conditions.
    For Loop: controlling multiple LEDs with a for loop and.
    Array: a variation on the For Loop example that demonstrates how to use an array.
    While Loop: how to use a while loop to calibrate a sensor while a button is being read.
  2. #32
    مدیر اصلی
    Aug 2012
    سلام خدمت دوستان Amyta و saeb و سایر دوستان...
    با اتوجه به اینکه تا الان چند نفر از دوستان اعلام آمادگی کردن ولی متاسفانه فقط یک نفر موفق شده که ترجمه رو به پایان برسونه فعلا منتظر هستیم ببینیم اگر اون دوستانیکه پروژه انتخاب کردن قادر به اتمام کار نیستن پروژ هاشون رو به سایر دوستان بدیم چون اولویت ما با ترجه پروژهای ساده و ابتدایی هست و با توجه به اینکه پروژها قبلا انتخاب شده دیگران قادر به انتخاب اونها نیستن و همین باعث میشه که دوستان جدید پروژهای تخصصی تر رو انتخاب کنن که با توجه به اینکه هنوز پروژهای ساده تر ترجمه نشدن، پروژهای پیشرفته و ترجمه سایر آموزش ها فعلا مد نظر ما نیست .
    برای همین دوستان یا پروژهای ساده و کامل ، (نه جزئی از آموزش یک مبحث کلی) رو انتخاب و یا صبر کنن تا دوستانی که قبلا پروژه انتخاب کردن تکلیف پروژه ها رو معین کنند.
  3. #33
    Aug 2014
    ایا هنوز این سیستم هست ؟ :d
    Mar 2016
    سلام...
    من تازه عضو شدم....
    هنوز این داستان جایزه یا هدیه وجود داره؟
    اگ هست ک آستینا رو بزنم بالا...
