نمایش نتایج: از 1 به 10 از 37
Like Tree13 لایک
موضوع: تنظیم رطوبت و دمای گلخانه توسط آردینو
    یه فیلم گرفتم از روش کار کردنش:
    http://s7.picofile.com/file/82383647...22004.zip.html
    #include <EEPROM.h>
    #include <Bounce2.h>
    #include <DHT.h>
    #include <LiquidCrystal.h>
    #define setBUTTON 13
    #define upBUTTON 12
    #define downBUTTON 11
    #define DHTPIN 2
    #define DHTTYPE DHT21
    Bounce set;
    Bounce up;
    Bounce down;
    DHT dht(DHTPIN, DHTTYPE);
    LiquidCrystal lcd(8, 7, 6, 5, 4, 3);
      const byte temprelay = 10, humidityrelay = 9;
      byte humiditySetpoint = 85;
      byte tempSetpoint = 20;
      unsigned long prevMillis = 0;
      unsigned long currentmillis = millis();
      static byte prevdownButton;
      static byte prevupButton;
      static byte prevsetButton;
      static byte  prevSetMode;
      byte setMode;
      lcd.begin(16, 2);
      lcd.clear();
      dht.begin();
        set.attach (setBUTTON);
        set.interval(30);
        up.attach (upBUTTON);
        up.interval(30);
        down.attach (downBUTTON);
        down.interval(30);
          pinMode (setBUTTON, INPUT_PULLUP);
          pinMode (upBUTTON, INPUT_PULLUP);
          pinMode (downBUTTON, INPUT_PULLUP);
      humiditySetpoint = EEPROM.read(0);
      tempSetpoint = EEPROM.read(1);
      set.update();
      up.update();
      down.update();
      float h = dht.readHumidity();
      if (isnan(h) || isnan(t)) {
        lcd.clear();
        lcd.setCursor(1,0);
        lcd.print("Failed to read ");
        lcd.setCursor(0,1);
        lcd.print("from DHT sensor!");
        delay(2000);
        lcd.clear();
        return;
      if ((t) >= tempSetpoint){
      digitalWrite (temprelay, HIGH);
           else if ((t) <= tempSetpoint-5)
           digitalWrite (temprelay, LOW);
       if ((h) >= humiditySetpoint){
       digitalWrite (humidityrelay, LOW);
           else if ((h) <=humiditySetpoint-10)
           digitalWrite (humidityrelay, HIGH);
      if ( setMode != 0) {
        if (currentmillis - prevMillis >= 10000UL) {
          setMode = 0;
          prevMillis = currentmillis;
        if (set.fell()) {
          setMode++;
        prevsetButton = setBUTTON;
      if (setMode >= 3) {
        setMode = 0;
      if (setMode != prevSetMode) {
        lcd.clear();
        prevSetMode = setMode;
      switch (setMode) {
          case 0://normal
       lcd.print("Humidity:");
       lcd.setCursor(10,0);
       lcd.print(h);
       lcd.setCursor(15,0);
       lcd.print("%");
       lcd.setCursor(1,1);
       lcd.print("Temp:");
       lcd.setCursor(7,1);
       lcd.print(t);
       lcd.setCursor(12,1);
       lcd.print(" *C ");
          break;
        case 1://edit temp
          if ('upButton' != prevupButton) {
            if (up.fell()) {
              tempSetpoint = tempSetpoint + 1;
            prevupButton = 'upButton';
          if ('downButton' != prevdownButton) {
            if (down.fell()) {
              tempSetpoint = tempSetpoint - 1;
            prevdownButton = 'downButton';
          lcd.setCursor(0, 0);
          lcd.print("Set temp:");
          lcd.setCursor(7, 1);
          lcd.print(tempSetpoint);
          lcd.setCursor(9,1);
          lcd.print("*C");
          EEPROM.write(1, tempSetpoint);
          break;
        case 2://edit humidity
            if (up.fell()) {
              humiditySetpoint = humiditySetpoint + 1;
            if (down.fell()) {
              humiditySetpoint = humiditySetpoint - 1;
          lcd.print("Set Humidity:");
          lcd.print(humiditySetpoint);
          lcd.setCursor(9,1);
          lcd.print("%");
          EEPROM.write(0, humiditySetpoint);
          break;
    ویرایش توسط cjmj : 02-11-2016 در ساعت 07:45 PM
    Jun 2016
    VID_20160211_222004
    #include <EEPROM.h>
    #include <DHT.h>
    #define upBUTTON 12
    #define DHTPIN 2
    Bounce set;
    Bounce up;
    Bounce down;
      byte setMode;
      lcd.begin(16, 2);
      lcd.clear();
      dht.begin();
        set.interval(30);
        up.interval(30);
        down.interval(30);
      set.update();
      up.update();
      down.update();
        lcd.clear();
        lcd.setCursor(1,0);
        lcd.setCursor(0,1);
        delay(2000);
        lcd.clear();
        return;
          setMode = 0;
        if (set.fell()) {
          setMode++;
      if (setMode >= 3) {
        setMode = 0;
        lcd.clear();
      switch (setMode) {
          case 0://normal
       lcd.print(h);
       lcd.print("%");
       lcd.setCursor(1,1);
       lcd.print("Temp:");
       lcd.setCursor(7,1);
       lcd.print(t);
       lcd.print(" *C ");
          break;
        case 1://edit temp
            if (up.fell()) {
            if (down.fell()) {
          lcd.setCursor(9,1);
          lcd.print("*C");
          break;
            if (up.fell()) {
            if (down.fell()) {
          lcd.setCursor(9,1);
          lcd.print("%");
          break;
    من میخوام این پروژه رو بسازم ولی مبتدی هستم . اگه میشه قطعاتی که استفاده کردید و همچنین کد برنامه رو به من بدید .
    راستی اگه میشه ی توضیحی هم در مورد اتصال پبین ها به اردینو بهم بدی.
    ممونت میشم اگه کمکم کنی
    نقل قول نوشته اصلی توسط wolf نمایش پست ها
    توی این پروژه از موارد زیر استفاده شده :
    ماژول آماده سنسور دما و رطوبت - آب و هوا AM2301/DHT21
    LCD کارکتری 1602 آبی - ال سی دی کاراکتری 16x2 - نمایشگر 2*16 کارکتری - LCD 1602
    http://shop.aftabrayaneh.com/Arduino_UNO_R3.html
    کلید فشاری مینیاتوری - میکرو سوئیچ
    اتصال تک تک اینها جداگانه هست
    شما وصل می کنی ( میتونی از هدر برنامه هم کمک بگیری)
    این دوست عزیزمون هم کد کدشون رو در طبق اخلاص گذاشتن
    البته علاوه بر اینها یک سری سیم بردبردی هم میخوای
    جستجو - dupo
    اگر قصد دارید این رشته رو ادامه بدید به نظر من از هر کدوم 40 تا بخرید چون زمان هایی پیش میاد که از نون شب واجب ترن
    Oct 2016
    من همچین منویی میخوام درست کنم اما نمیدونم از کجا شروع کنم .کپی کردنم بلد نیستم چون ماژول هام فرق میکنه من سنسور دماsht دارم lcd که فرقی نمیکنه بلوتوث ساعت و رله چهار کانال که به زودی 4 کانال دیگه اضافه میشه و یک سنسور فتوسل
    ی منوی تنظیم همچین مدلی میخوام باشه که بشه دستی تنظیم کنی دما رطوبت و....
    کسی هست که کدهایی ک تا الان درست کردم بدم برام منوش بسازه ؟
    May 2018
    ترو خدا به منم کمک کنین بسازم😢
    سلام من اصلا بلد نیستم چطوری سیم بندی شده به منم یاد بدید چطوریه خواهش میکنم🤕
    May 2018
    VID_20160211_222004
    #include <EEPROM.h>
    #include <DHT.h>
    #define upBUTTON 12
    #define DHTPIN 2
    Bounce set;
    Bounce up;
    Bounce down;
      byte setMode;
      lcd.begin(16, 2);
      lcd.clear();
      dht.begin();
        set.interval(30);
        up.interval(30);
        down.interval(30);
      set.update();
      up.update();
      down.update();
        lcd.clear();
        lcd.setCursor(1,0);
        lcd.setCursor(0,1);
        delay(2000);
        lcd.clear();
        return;
          setMode = 0;
        if (set.fell()) {
          setMode++;
      if (setMode >= 3) {
        setMode = 0;
        lcd.clear();
      switch (setMode) {
          case 0://normal
       lcd.print(h);
       lcd.print("%");
       lcd.setCursor(1,1);
       lcd.print("Temp:");
       lcd.setCursor(7,1);
       lcd.print(t);
       lcd.print(" *C ");
          break;
        case 1://edit temp
            if (up.fell()) {
            if (down.fell()) {
          lcd.setCursor(9,1);
          lcd.print("*C");
          break;
            if (up.fell()) {
            if (down.fell()) {
          lcd.setCursor(9,1);
          lcd.print("%");
          break;
    منم مبتدی هستم اگه میشه آموزش سیم بندی رو هم قرار بدین ممنون
