نمایش نتایج: از 1 به 10 از 40
موضوع: درخواست کمک برای کد در آردیـــنو
    کد هایی که الان دارم اینهاســـــت!
    کد HTML:
    #include "EmonLib.h"  // Include Emon Library
    EnergyMonitor emon1;  // Create an instance
    // include LCD the library:
    #include <LiquidCrystal.h>
      // initialize the library with the numbers of the interface pins
      Serial.begin(9600);   // set up the LCD’s number of columns and rows:
      lcd.begin(20, 4);
      emon1.voltage(2, 234.26, 1.7);  // Voltage: input pin, calibration, phase_shift
      emon1.current(1, 111.1);  // Current: input pin, calibration.
      emon1.calcVI(20,2000);  // Calculate all. No.of half wavelengths (crossings), time-out
      emon1.serialprint();  // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
        unsigned int long timemillis=millis();  //keeping the track of the time since the device is switched ON
      unsigned int long time=timemillis/1000;
       float realPower       = emon1.realPower; //extract Real Power into variable
      float apparentPower   = emon1.apparentPower;  //extract Apparent Power into variable
      float powerFactor=emon1.powerFactor;//extract Apparent Power into variable rFactor     = emon1.powerFactor; //extract Power Factor into Variable
      float supplyVoltage   = emon1.Vrms; //extract Irms into Variable
      float Irms            = emon1.Irms;
      //displaying the values
    lcd.setCursor(1,0);
    lcd.print("Energy Monitor");
    lcd.setCursor(0,1);
    lcd.print("V=");
    lcd.print(supplyVoltage);
    lcd.setCursor(9,1);
    lcd.print("I=");
    lcd.print(Irms);
    lcd.setCursor(-4,2);
    lcd.print("PowerFactor=");
    lcd.print(powerFactor);
    lcd.setCursor(-4,3);
    lcd.print("Units(kWh)=");
    lcd.print(abs(realPower*time)/abs(1000*3600));
    lcd.setCursor(-4,4);
    lcd.print("(kW)=");
    lcd.print(realPower/1000);
    lcd.setCursor(-4,5);
    lcd.print("(KVA)=");
    lcd.print(apparentPower/1000);
    lcd.setCursor(-4,6);
    lcd.print("(KVAR)=");
    lcd.print((sqrt((apparentPower*apparentPower)-(realPower*realPower)))/1000);
    نقل قول نوشته اصلی توسط paddesky نمایش پست ها
    کد HTML:
      lcd.begin(20, 4);
    lcd.setCursor(1,0);
    lcd.setCursor(0,1);
    lcd.print("V=");
    lcd.setCursor(9,1);
    lcd.print("I=");
    lcd.print(Irms);
    lcd.print("(kW)=");
    دقیقا توضیح میدی آخر پروژه ات چیه ؟
    یعنی اگه از شیلد ال سی دی 1602 استفاده کنم، بدون اینکه کدی وارد برنامه کنم صفحه عوض می کنه برای نمایش دیگر پارامترها؟
    پروژه ام یک Power Meter هست، توان یک وسیله برقی یا واحد مسکونی را اندازه گیری و مونیتور می کنه، با استفاده از یکی از لایبرری های آردینو...
    البته که نه !
    کدش اینجاست:
    http://forum.arduino.ir/8/21/812.html#post3283
    خاصیت این شیلد این هست که برای صفحه عوض کردن نمیخواد میکروسوئیچ جداگانه بزاری همین خودش روش داره
    البته که نه !
    کدش اینجاست:
    ممنون، همین الان سفارش دادم، امـــیدوارم بتونم کداش را درست کنم، حتمی دوباره به راهنمایی شما نیاز خواهم داشت
    هر سوالی داشتی بپرس
