کد برای کاربر client
کد:#include "SIM900.h" #include <NewSoftSerial.h> #include "inetGSM.h" //GSM Shield for Arduino //www.open-electronics.org //this code is based on the example of Arduino Labs. //Simple sketch to start a connection as client. InetGSM inet; char msg[100]; int numdata; char inSerial[30]; int i=0; void setup() { //Serial connection. Serial.begin(9600); Serial.println("GSM Shield testing."); //Start configuration of shield with baudrate. //For http uses is raccomanded to use 4800 or slower. if (gsm.begin(4800)) Serial.println("\nstatus=READY"); else Serial.println("\nstatus=IDLE"); //GPRS attach, put in order APN, username and password. //If no needed auth let them blank. if (gsm.attachGPRS("internet.wind", "", "")) Serial.println("status=ATTACHED"); else Serial.println("status=ERROR"); delay(5000); //TCP Client GET, send a GET request to the server and //save the reply. numdata=inet.httpGET("www.google.com", 80, "/", msg, 100); //Print the results. Serial.println("\nNumber of data received:"); Serial.println(numdata); Serial.println("Data received:"); Serial.println(msg); //Tweet //inet.tweet("*********************key************", "An Arduino at #cpes15"); }; void loop() { //Read for new byte on serial hardware, //and write them on NewSoftSerial. serialhwread(); //Read for new byte on NewSoftSerial. serialswread(); }; void serialhwread(){ i=0; if (Serial.available() > 0){ while (Serial.available() > 0) { inSerial[i]=(Serial.read()); delay(10); i++; } inSerial[i]='\0'; if(!strcmp(inSerial,"/END")){ Serial.println("_"); inSerial[0]=0x1a; inSerial[1]='\0'; gsm.SimpleWrite(inSerial); } //Send a saved AT command using serial port. if(!strcmp(inSerial,"TEST")){ Serial.println("SIGNAL QUALITY"); gsm.SimpleWrite("AT+CSQ"); } //Read last message saved. if(!strcmp(inSerial,"MSG")){ Serial.println(msg); } else{ Serial.println(inSerial); gsm.SimpleWrite(inSerial); } inSerial[0]='\0'; } } void serialswread(){ gsm.SimpleRead(); }
کد برای Server
کد:#include "SIM900.h" #include <NewSoftSerial.h> #include "inetGSM.h" //GSM Shield for Arduino //www.open-electronics.org //this code is based on the example of Arduino Labs. //Simple sketch to start a connection as server. InetGSM inet; char msg[100]; int numdata; char inSerial[30]; int i=0; long lasttime; void setup() { //Serial connection. Serial.begin(9600); Serial.println("GSM Shield testing."); //Start configuration of shield with baudrate. //For http uses is raccomanded to use 4800 or slower. if (gsm.begin(4800)) Serial.println("\nstatus=READY"); else Serial.println("\nstatus=IDLE"); //GPRS attach, put in order APN, username and password. //If no needed auth let them blank. if (gsm.attachGPRS("internet.wind", "", "")) Serial.println("status=ATTACHED"); else Serial.println("status=ERROR"); delay(5000); //Read IP address. int i=0; while(i<20){ gsm.SimpleRead(); i++; } delay(5000); gsm.write((const uint8_t*)"AT+CIFSR\r", 10); gsm.read(msg, 200); Serial.println(msg); delay(5000); //Tweet //inet.tweet("*********************key************", "An Arduino at #cpes15"); //TCP Server. Start the socket connection //as server on the assigned port. Serial.println(msg); delay(5000); if (gsm.connectTCPServer(80)) Serial.println("status=TCPSERVERWAIT"); else Serial.println("ERROR in Server"); lasttime=millis(); }; void loop(){ //serialhwread(); //serialswread(); //Check if there is an active connection. if (gsm.connectedClient()){ //Read and print the last message received. gsm.read(msg, 200); Serial.println(msg); } }; /* void loop() { serialhwread(); serialswread(); }; */ void serialhwread(){ i=0; if (Serial.available() > 0){ while (Serial.available() > 0) { inSerial[i]=(Serial.read()); delay(10); i++; } inSerial[i]='\0'; if(!strcmp(inSerial,"/END")){ Serial.println("_"); inSerial[0]=0x1a; inSerial[1]='\0'; gsm.SimpleWrite(inSerial); } //Send a saved AT command using serial port. if(!strcmp(inSerial,"TEST")){ Serial.println("SIGNAL QUALITY"); gsm.SimpleWrite("AT+CSQ"); } //Read last message saved. if(!strcmp(inSerial,"MSG")){ Serial.println(msg); } else{ Serial.println(inSerial); gsm.SimpleWrite(inSerial); } inSerial[0]='\0'; } } void serialswread(){ gsm.SimpleRead(); }
لینک دانلود کتابخانه های مورد نیاز gsm-shield-arduino - GSM Shield Library for Arduino - Google Project Hosting
(باید با استفاده از VPN دانلود کنید، به دلیل تحریم ها)
7 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
