نمایش نتایج: از 1 به 6 از 6
  • 1 Post By Smead
موضوع: لچ کردن خروجی های gpio در ماژول esp8266
Threaded View
  1. #5
    https://www.arduino.cc/en/Tutorial/EEPROMWrite
    به این مثال توجه کن
    #include <EEPROM.h>
      uint addr = 0;
      // fake data
      struct {
        uint val = 0;
        char str[20] = "";
      } data;
      // commit 512 bytes of ESP8266 flash (for "EEPROM" emulation)
      // this step actually loads the content (512 bytes) of flash into
      // a 512-byte-array cache in RAM
      EEPROM.begin(512);
      // read bytes (i.e. sizeof(data) from "EEPROM"),
      // in reality, reads from byte-array cache
      // cast bytes into structure called data
      EEPROM.get(addr,data);
      Serial.println("Old values are: "+String(data.val)+","+String(data.str));
      // fiddle with the data "read" from EEPROM
      data.val += 5;
      if ( strcmp(data.str,"hello") == 0 )
          strncpy(data.str, "jerry",20);
          strncpy(data.str, "hello",20);
      // replace values in byte-array cache with modified data
      // no changes made to flash, all in local byte-array cache
      EEPROM.put(addr,data);
      // actually write the content of byte-array cache to
      // hardware flash.  flash write occurs if and only if one or more byte
      // in byte-array cache has been changed, but if so, ALL 512 bytes are
      // written to flash
      EEPROM.commit();
      // clear 'data' structure
      data.val = 0;
      strncpy(data.str,"",20);
      // reload data for EEPROM, see the change
      //   OOPS, not actually reading flash, but reading byte-array cache (in RAM),
      //   power cycle ESP8266 to really see the flash/"EEPROM" updated
      Serial.println("New values are: "+String(data.val)+","+String(data.str));
    همچنین بهتره از put و get بجای write و read استفاده کنین
    ممنون از لطف و پاسخ شما. حل شد
    مشکل من در EEPROM.commit بود که بعد از دستور put ننوشته بودم وگرنه با دستورات put و get هم امتحان کرده بودم.
    ویرایش توسط esmaeil57 : 01-16-2019 در ساعت 09:00 AM
