تنها چیزی که من تونستم بفهمم اینه که 45 پین هست
هیچ جا نگفته تا چه اینچی ساپرت می کنه .
19 اینچ رو هیچ نظری ندارم
اما به نظرم 7 رو ساپرت میکنه
RGB LCD Interface Pin Spec
Pin# Name Description
1, 2 VDD_5V 5V Output, it can be used to power LCD modules
11,20,29, 37,38,39,40, 45 DGND Ground
3-10 Blue LSB to MSB RGB blue
12-19 Green LSB to MSB RGB green
21-28 Red LSB to MSB RGB red
30 GPIOB25 available for users
31 GPIOC15 occupied by FriendlyARM one wire technology to recognize LCD models and control backlight and implement resistive touch, not applicable for users
32 XnRSTOUT Form CPU low when system is reset
33 VDEN signal the external LCD that data is valid on the data bus
34 VSYNC vertical synchronization
35 HSYNC horizontal synchronization
36 LCDCLK LCD clock, Pixel frequency
41 I2C2_SCL I2C2 clock signal, for capacitive touch data transmission
42 I2C2_SDA I2C2 data signal, for capacitive touch data transmission
43 GPIOC16 interrupt pin for capacitive touch, used with I2C2
44 NC Not connected
