after opening the serial monitor, you should see different values printed on a line and refreshed very quickly. these are the state of the various buttons present on the joystick shield, as well as the
.current position (x and y value) of the joystick
کد:// Store the Arduino pin associated with each input // Select button is triggered when joystick is pressed const byte PIN_BUTTON_SELECT = 8; const byte PIN_BUTTON_F = 7; const byte PIN_BUTTON_E = 6; const byte PIN_BUTTON_RIGHT = 3; const byte PIN_BUTTON_UP = 2; const byte PIN_BUTTON_DOWN = 4; const byte PIN_BUTTON_LEFT = 5; const byte PIN_ANALOG_X = 0; const byte PIN_ANALOG_Y = 1; void setup() { Serial.begin(9600); pinMode(PIN_BUTTON_RIGHT, INPUT); digitalWrite(PIN_BUTTON_RIGHT, HIGH); pinMode(PIN_BUTTON_LEFT, INPUT); digitalWrite(PIN_BUTTON_LEFT, HIGH); pinMode(PIN_BUTTON_UP, INPUT); digitalWrite(PIN_BUTTON_UP, HIGH); pinMode(PIN_BUTTON_DOWN, INPUT); digitalWrite(PIN_BUTTON_DOWN, HIGH); pinMode(PIN_BUTTON_SELECT, INPUT); digitalWrite(PIN_BUTTON_SELECT, HIGH); pinMode(PIN_BUTTON_E, INPUT); digitalWrite(PIN_BUTTON_E, HIGH); pinMode(PIN_BUTTON_F, INPUT); digitalWrite(PIN_BUTTON_F, HIGH); } void loop() { Serial.print("U:"); Serial.print(digitalRead(PIN_BUTTON_UP)); Serial.print(" "); Serial.print("R:"); Serial.print(digitalRead(PIN_BUTTON_RIGHT)); Serial.print(" "); Serial.print("D:"); Serial.print(digitalRead(PIN_BUTTON_DOWN)); Serial.print(" "); Serial.print("L:"); Serial.print(digitalRead(PIN_BUTTON_LEFT)); Serial.print(" "); Serial.print("x:"); Serial.print(analogRead(PIN_ANALOG_X)); Serial.print(" "); Serial.print("y:"); Serial.print(analogRead(PIN_ANALOG_Y)); Serial.print(" "); Serial.print("S:"); Serial.print(digitalRead(PIN_BUTTON_SELECT)); Serial.print(" "); Serial.print("F:"); Serial.print(digitalRead(PIN_BUTTON_F)); Serial.print(" "); Serial.print("E:"); Serial.print(digitalRead(PIN_BUTTON_E)); Serial.print(" "); Serial.println(); }
 LinkBack URL
 About LinkBacks
  پاسخ با نقل قول
